Old 01-21-2020, 09:43 PM
Cannon Cannon is offline
Default Can this be fixed (belly sheet metal bend)?
I finally got my second-hand RV-8 on a rotisserie, and when we spun it upside down, I could see that the belly skin that becomes the lower wing root fairing was creased.
It looks like the previous builder set the fuselage on some padding and bent the belly skin where it extends past the fuselage sides.
Would something like a wood block and some light taps with a flush rivet set work? It?s on the belly, so I?m not really concerned, but if there?s an easy fix I?m all ears.
C-185
J3C-65
S1S
RV-8 under construction
Old 01-22-2020, 02:12 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default metal shaping
Originally Posted by Cannon View Post
...Would something like a wood block and some light taps with a flush rivet set work? It?s on the belly, so I?m not really concerned, but if there?s an easy fix I?m all ears.
Can't see the photo since I'm at work and they are blocking smugmug, but if you watch a few of this guy's videos you will feel that you can do anything with sheet metal. https://www.lazzemetalshaping.com/
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-22-2020, 07:09 AM
BobbyLucas's Avatar
BobbyLucas BobbyLucas is offline
Same with 1st Track Dents on YouTube: https://www.youtube.com/channel/UCUy...n64Ppd34qCtAvw
It's absolutely insane what this guy can do with paintless dent removal, both steel and aluminum. I couldn't stop watching his videos. But I'm a dork, so YMMV.
Looks like Lazze has a YouTube channel as well, I'll have to check that out: https://www.youtube.com/user/lazzemetalshaping
Bobby Steinmetz
Van Buren TWP, MI
Student Pilot, Mechanical Engineer, Donating Member
RV-12iS #121228
  • My opinions are JUST my opinions, not facts
  • Regardless of phrasing or colorfulness, my opinion does not imply that any opposing opinions are wrong or ANY less valid than my own
  • Respect people by giving your own opinion without attacking or belittling others
  • Passive-aggressive is not better than overt-aggressive
  • When I fail to meet these standards, please call me out, gently
Old 01-22-2020, 07:18 AM
BobbyLucas's Avatar
Maybe a Nylon peening tool? Might just end up making things worse and work-hardening the thin aluminum in the process though.
https://www.aircraft-tool.com/shop/d...ookieSupport=1
Bobby Steinmetz
Van Buren TWP, MI
RV-12iS #121228
Old 01-22-2020, 07:58 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
It's a little difficult to tell from the photo, but when you interface that area with the wing, some of that may disappear. I wouldn't mess with it right now because I think it's highly likely that you'll work harden the area by messing with it. Plus since it's on the bottom, who will notice?
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
Old 01-22-2020, 09:31 AM
JonJay's Avatar
JonJay JonJay is offline
Have the wings and flaps ever been on ?
Can?t tell from the pic but the flap to fuselage interface sometimes doesn?t match up. This is the area the folks bend up or down to close that gap over the flap push rod hole.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-22-2020, 10:17 AM
Go to a good auto body shop and hire their best sheet metal guy for some after-hours work. It's remarkable what they can do.
Dave
Old 01-22-2020, 10:54 AM
Agreed - that?s the way I?m leaning at the moment.
Chris
C-185
J3C-65
S1S
Old 01-22-2020, 10:56 AM
Wings have never been on.
C-185
J3C-65
S1S
Old 01-22-2020, 10:58 AM
Dave
Thanks, David. Hadn?t thought of that. Do any of those guys work with aluminum? I?m assuming it works differently to steel.
C-185
J3C-65
S1S
