Old 04-03-2019, 09:03 AM
fl9500's Avatar
fl9500 fl9500 is offline
Default Metal in Oil Filter
Hi,
after my last Oil-change, I found more than normal? magnetic metal in my Oil Filter. Lycoming O360, ~1200 Hours. ~7month and 40hours after last Oilchange.
For the first time I used CAMGUARD.
I now want to fly it for a few hours and then check again.
Any tips what to do next ?
Achim
PH-CRJ RV6A at EDVM, Germany
Old 04-03-2019, 10:07 AM
BobRv4 BobRv4 is offline
Default Pull a jug
I would think the cam is getting ate up. Pull a cyl and check cam.
Old 04-03-2019, 10:28 AM
JonJay's Avatar
JonJay JonJay is offline
Put your magnet in a plastic bag next time so you can easily separate the metal from the magnet. The magnet works fine through a thin layer of plastic. Typically you want to measure how much metal is there and start trending it, although it appears to be more than enough to be concerned and it is a “new” event, also concerning.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 04-03-2019, 11:19 AM
Jpm757's Avatar
Jpm757 Jpm757 is offline
Most logical source of this in an infrequently flown Lycoming would be the lifters.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Building Javron Super Cub.
2020 dues gladly paid.
Old 04-03-2019, 12:17 PM
rdrcrmatt rdrcrmatt is offline
Send the oil out for analysis.
Lycoming's SB for metal in the oil is pretty clear. New filter, new oil, run it for a little and check again.
https://www.lycoming.com/sites/defau...e%20Action.pdf
Start reading at page 8.
Matt
CFI / RV-10
Old 04-03-2019, 07:18 PM
titanhank titanhank is offline
Pull a cylinder on each side and inspect the cam now before the metal has embedded in your piston skirts and ruined the jugs. Hopefully you have caught it in time. I just rebuilt my engine myself with new jugs. Cost me $20k, but my crank, cam and lifters all red tagged. I bet you have a few lifter that look like this.
Harmon Rocket #1
IO-540
10-1 pistons
1959 Piper PA22-150 Tri-Pacer
Rv7a sold
Rv6 sold
Rv4 sold
Rv3 sold
Old 04-03-2019, 11:32 PM
johnf_1 johnf_1 is offline
Default Tear down
Sorry, I do not know of anything benign that generates that much ferrous metal between oil changes. My guess: lifters/cam/oil pump gears....but nothing that is good or getting better. Good news: engines are easy to disassemble and re-assemble....had a similar event in 1994 (cam/lifters), and flying behind the re-build now...best, John
Old 04-04-2019, 06:53 AM
mahlon_r mahlon_r is offline
My thoughts are to ground the aircraft until the source and remedy is determined. That is way, way to much steel in the filter from one oil change interval to ignore or to fly and see. Granted it looks as though it might be a cam lobe, tappet face spalling but maybe not. It's sizable STEEL! not fine rust scraped off something. Steel chips of that size means, if it isn't a cam lobe, something very structural to the engine or its operation is wearing and shedding metal at a very, very abnormal rate. Trust me, its not going to go away and it will increase in severity the more you operate the engine. If it is a cam lobe, operating the engine further will only increase the risk of unrepairable damage to the crankshaft, pistons, oil pump etc. Time to ground that aircraft before you do more damage to the engine and possibly to your self or your aircraft. There is no upside to continue operating the engine.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 04-04-2019, 07:08 AM
Walt's Avatar
Walt Walt is online now
Listen to Mahlon, he knows what he's talking about!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 04-04-2019, 08:45 AM
moosepileit moosepileit is offline
Please post any suction screen findings when removal starts. Sorry for the downtime and expense.
Thank you for weighing in, Mahlon!
RV-6, bought from builder.
O-320, slider, carb, mags, FP
