Old 03-16-2019, 03:57 PM
JBPILOT JBPILOT is offline
Default MILESTONE RV-12 1300 hours
Been a terrible winter. First flight in 2 full months. Almost forgot to take pic.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-2021 )
Old 03-16-2019, 06:43 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Fantastic accomplishment. I own SN120058 but only have 400TT.
Can you tell us you experience with the Rotax 912ULS over the 1300 hours of operation?
  • Major maintenance?
  • Oil and fuel type used?
  • Consuming any oil between changes?
  • Gearbox?
  • Carb problems?
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 750
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 03-17-2019, 08:40 AM
Default RV-12 912ULS history with 1300 hours
1. Had to replace both original 'Green Stripe' Ign Modules. Both failed between 400 - 500 hours. Went to new Yellow Stripe 'soft-start' modules.
2. Always used Aeroshell Sport plus 4, and ALWAYS premium auto fuel.
3. Uses terrible amounts of oil. Almost a quart in 100 hours. ( joking )
4. Gearbox seems good. Test friction at annual.
5. I rebuilt carbs at 5 years. Will again this year ( 10 years ).
I would say it runs exactly as it did day one. Flew about 290 statute miles yesterday to Janesville Wisc. and back.
John Bender
Old 03-17-2019, 09:46 AM
Piper J3's Avatar
About what I was expecting to hear except for the ignition modules. Maybe I should start saving for a Christmas fund...
Other threads on this forum talk about prop balancing and mid-range vibration. What is your experience now with 1300TT?
Living in IA, I suspect you religiously pre-heat engine in winter months?
Old 03-17-2019, 03:54 PM
Default RV-12 1300 Hours
I do check my Carb balance at least once a year. Seems very stable after this many years, which I would expect.
Have prop set to .1 degree also. Always has had a vibration RPM about mid-range. Smooth above and below it. I just stay away from that range.
Yes, when below 50 degrees, I leave it plugged in all the time.
Helps the battery also I'm sure. I am still on original battery. 10 years is good. Seems strong yet.
John Bender
Old 03-17-2019, 04:36 PM
Dave12 Dave12 is offline
Congratulations JB. Always at the head of the pack!
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Old 03-17-2019, 04:51 PM
n18pf's Avatar
n18pf n18pf is offline
Default Congratulations!
Great accomplishment John! It was an honor to join you in Janesville yesterday.
Paul A. Fisher
RV-7A N18PF
Q-200 N17PF
APRS track
Old 03-18-2019, 09:22 AM
funflying funflying is offline
John you have always been a great resource of information and experience. Keep blazing the trail.
One question about oil circulation. Do you have the oil thermostat? I read you do preheat but I wondered about warm up after start. Thanks
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 03-18-2019, 10:31 AM
Piper J3's Avatar
As a data point, I have E-Z HEAT 912 engine pre-heater which consists of two silicone heater pads – one for bottom of crankcase and the other wraps around bottom of oil tank. I have a remote cellphone relay switch so I can turn unit on well in advance of engine start. If OAT is 20-30F I’ll pre-heat for 180 minutes. When I arrive at the airplane the oil and water temps are 80F and I’m good to go.
Old 03-18-2019, 01:07 PM
JwWright57 JwWright57 is offline
Thumbs up
Congrats John, nice milestone
Jeff Wright, Charlotte NC
Rv-12is with 912is and Dynon system.
Certified Aug 2021
Dues paid 2021
