Go Back   VAF Forums > Model Specific > RV-14
Old 04-22-2018, 05:16 AM
StressedOut StressedOut is offline
Default Disaster! I?m seriously depressed.
All that was left on my rudder was the riveting of the trailing edge and rolling the leading edge. I used Proseal on the wedge instead of tape, so after it cured I was clearing the holes of excess Proseal and discovered that almost all of the TE holes were double drilled (binocular).
Thinking back I know exactly where this happened. I used a rectangular steel tube to cleco the TE against. I match drilled holes using the TE as a guide. It served its purpose well. I had a perfectly straight TE. I just didn?t use enough care in the match drilling the tube.
The holes look to be about 15 to 20 percent oblong. I think I?m going to buy new parts and rebuild the rudder. I?m not comfortable with such a defect. The cost is about $320 plus shipping. This is a hard lesson to learn. It?s not the cost that bothers me as much as the 40 or so hours I have to spend rebuilding the rudder.
Art Jackson
RV-14A Kit#140433
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator, Rudder #2, Aft Fuselage)
Ordered: Wing Kit (Arrives March 2021)
Construction log - mykitlog.com/ajackson
Dues paid on March 2021
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
Old 04-22-2018, 05:24 AM
YellowJacket RV9 YellowJacket RV9 is offline
I rebuilt what in hindsight would have been a totally airworthy horizontal stabilizer, due to some newbie cosmetic mistakes. I know it stings, but in the long run the extra time and effort will be a rounding error compared to your total build.
One suggestion to feel better is to hold off on building a new one until later. Just move to the next project until you feel better or actually need to mount the rudder.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 04-22-2018, 06:46 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by StressedOut View Post
I think I’m going to buy new parts and rebuild the rudder. I’m not comfortable with such a defect. The cost is about $320 plus shipping. This is a hard lesson to learn. It’s not the cost that bothers me as much as the 40 or so hours I have to spend rebuilding the rudder.
It's not a disaster. It is education and recreation. Shrug it off. And bravo to you for not accepting defects. The best time to adopt that habit is right where you are now, building the tail.
News flash....the best builders throw away a lot of parts.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-22-2018, 07:00 AM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Bad part
Your experience is normal! I spent about a month making custom wheel pants, they were beautiful, but I missed centering the hole for the tire and it just looked bad, bad, bad.
I kept them under my work bench for a year as a reminder that sometimes you just start over and end up with a better plane.
I find Makers Mark is an appropriate builders tool. 😊
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 750+
2021 Dues Paid
The Dues Paid note is a reminder for me
Old 04-22-2018, 08:13 AM
bkervaski's Avatar
bkervaski bkervaski is offline
Many of us experienced the rudder twice! I feel your pain ... I was down to the last few rivets and made an aweful cosmetic mistake ... the second one will go a lot faster and will be better quality ... the first one was just practice
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 04-22-2018, 08:18 AM
BillL BillL is offline
Thumbs up
Yep - Like Dan sez - - educational.
Besides, it would have cost you 3 kts too.
Bill
RV-7
Old 04-22-2018, 08:46 AM
mturnerb mturnerb is offline
I built 3 elevators - 2 left and one right. Did re-use the trim tab!
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 04-22-2018, 08:47 AM
bkervaski's Avatar
I built 5 trim tabs. Vans thought I was a crazy person, my girlfriend and co-builder (now fiance, somehow) thought the same.
The re-do's seemed to calm down towards the end of the empennage.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 04-22-2018, 08:57 AM
painless painless is offline
You now have some wall art for your man cave.
Press on.
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 04-22-2018, 08:58 AM
Tom023 Tom023 is offline
Chris
+1. And I thought I was the only one. I built my second one almost two years later because the mistake was visible and bugged me the entire time. Adding insult to injury, the replacement spar was misdrilled so I needed a third at $125 shipping alone! Now it?s perfect and I get satisfaction every time I look at it. Just part of the building process.
RV14A #140083
Flying! 8/12/19
2020 Donation
