Old 12-21-2017, 11:30 AM
j-red j-red is offline
Default Is my engine self-destructing?
I love to learn. That's one of the things that got me into the airplane building thing. It's also taught me that there's a lot I have yet to learn...
I have a lycoming o-360, 675 hours SNEW, but was recently rebuilt (by me) in response to a prop strike. Case professionally cleaned, cam and crank polished, tappets overhauled, new bearings, overhauled jugs, new pistons, piston pins, etc. It now has about 75 hours on it since the rebuild. These 75 hours have been accrued over the past 9 months.
The engine uses virtually no oil, and has made good compression (78+/80 at 10 and 50 hours, haven't checked it since), and runs smooth and strong. Oil temps are a little low, but fine and pressure is about 80psi in cruise, 60 at idle.
After the rebuild, I ran the engine for about 10 hours, then replaced the oil and filter. I didn't have the oil analyzed (I said I had lots to learn), but did open up the filter and didn't notice any metal of any kind in it. I didn't wash the filter with mineral spirits or anything, so it could be that i just didn't notice but there was some there. Between 25 & 30 hours later, I drained the oil, but did not replace the filter. I was told that the filter was good for 50 hours, so i thought i'd only replace it every other time. In retrospect, this might be fine later down the road, but was foolish at the very beginning of the run in that the filter could have provided useful information. I did, however, send off a sample of the oil to Blackstone for analysis. Metals were a little high, but that was expected for an engine just breaking in. Fast forward to about 2 weeks ago. 25 hours have passed and it's time for another oil change. This time oil and filter were changed. Oil was sent off, and the filter sat in the bucket waiting for me to get around to checking it. Report came back that iron and aluminum had actually increased slightly, and after only 25 hours instead of 30. Alarmed, I immediately cut open the filter to inspect it, and have lots of miniscule shiny non-ferrous bits in there as well as a couple half-inch long hairlike slivers of ferrous metal. I'd guess there's a shiny speck in almost every pleat, and a few pleats with quite a few. They're embeded in there, so collecting them for a teaspoon reading isn't going to happen... Running a magnet over the filter reveals virtually no iron dust or anything else.
What I don't know is:
Do I have a major problem that has trashed my bearings already, or am I totally flipping out over absolutely nothing?
Is this typical metal wear for a new engine and a filter with 50 hours on it?
One helpful avweb article mentioned flakes of aluminum and hairs of steel pointed to a broken ring. I have a borescope and wonder what I should be looking for in that regard?
The plan right now is to scope the cylinders the next time I'm at the airport, then run for ten more hours before pulling the filter for inspection.
Here is a video that shows the filter, and it really doesn't do it justice. Every little white speck is a shiny piece of metal.
https://youtu.be/2APnb5haYak
And the oil Analysis:
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
Old 12-21-2017, 02:25 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I don't see anything alarming in either the oil analysis or the video Jon - you should expect some particles while the engine breaks in, and even the oil analysis says that you should consider a borescope "if you see any unusual temperatures". He mentions the potential for having glazed cyclinders - you'd know this by high oil consumption - what are you seeing for hours/quart?
The particles in the filter coudl be there from anytim,e since hour 11 (if I understand your post), and there really isn't very much there - nothing that would trigger my alarm bells if I was flying behind the engine.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-21-2017, 02:42 PM
vic syracuse vic syracuse is offline
Super Moderator
What you are seeing is perfectly normal for a new/newly-rebuilt engine. Don't fret over it at all.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES/RW
Kitplanes "Unairworthy" "Diagnostics" monthly feature
EAA Sport Aviation "Checkpoints" monthly column
Author "Pre-Buy Guide for Amateur-Built Aircraft" & "Are your Nuts Tight?"
www.Baselegaviation.com
Old 12-21-2017, 03:15 PM
Aggie78 Aggie78 is offline
Default Some help found here...
A few articles on the subject by A&P IA/writer Mike Busch found here:
https://www.savvyaviation.com/wp-con...king-metal.pdf
https://www.avweb.com/news/savvyavia..._195044-1.html
And, the link to the Service Instruction referred to in the last article is bad...the SI can be found here:
https://www.lycoming.com/content/ser...ction-no-1492d
Hope that helps alleviate some of the concern.
Rob Schroer
RV-7/N75WV
YIO-360-M1B
New Braunfels, Texas (KBAZ)
Old 12-21-2017, 07:16 PM
tim2542 tim2542 is offline
If you squeeze the oil out of the element aggressively in a vice you will find (see) much more than if you just let it drain. It appears you may have done just that as the element looks dry.
Looks good but to be safe check it again in 25 hrs and watch for declining metals in the analysis.
Tim Andres
Old 12-21-2017, 09:22 PM
Thanks for the input guys. Makes me feel much better as I learn more about what is common/normal and not.
Rebuilt RV-6A N94CR
Old 12-21-2017, 11:14 PM
Webb's Avatar
Webb Webb is offline
I'm guessing you use an additive based on elements such as phosphorus.
Also I would say your air filter may be dirty based on the amount of silicone.
Webb Willmott
Jackson, MS
N32WW
Old 12-22-2017, 06:57 AM
BillL BillL is offline
Or he has new silicone VC gaskets.
Bill
RV-7
Old 12-22-2017, 07:05 AM
Tim Andres
Tim, as an alternative, you can take the pleats and sit on a bed of 1/2" of paper towels then spritz mineral spirits over the top and it will pull all the oil out of the filter paper and not disturb the accumulated surface material. A bar of steel ( a clean weight) to add better contact pressure with the towel bed helps wicking. It will get quite dry after about an hour. This was SOP in my former engine lab for filter inspection.
Bill
RV-7
Old 12-22-2017, 10:20 AM
Thanks Bill for both comments.
I?ve been watching elevated copper levels on mine since overhaul, especially with the Lycoming rod bushing fiasco (which I missed due to overhaul date) Then I realized I used ?copper coat? gasket sealer on some of the gaskets when I assembled it. While I?m not certain that product is behind the elevated number, I?m pretty sure I?ll see it drop over time. And I think that is the real value of these reports, establishing a base line and watching trends.
If RTV was used anywhere (hopefully very little or none), that will also cause high silicon numbers. I had not considered the silicon gaskets causing it.
Tim Andres
