Old 10-21-2017, 09:15 PM
Chris Engler Chris Engler is offline
Default Mystery of the Coughing XP-400 Finally Solved!
http://tinypic.com/usermedia.php?uo=...c#.Wev41GhSyM8
For those of you that have been following my "XP-400 Still Coughing" thread, I'm delighted to report I had to start a new thread with a different name since the problem has been identified.
After spending 2 months and changing out fuel servos, mags, exhaust, checking plugs, spider, injectors, confirming fuel flow and pressure, etc. etc., and not finding anything, I spent today at the airport, pulled the engine off the airplane, removed the accessory case and there it was....the cam to crank gear train was "one tooth off".
The engine would start and run fine till 2500 RPM then stumble and sputter rich. Leaning would clean up the coughing and allow 2600 RPM static. Many (including the mechanic on our filed) felt the engine would run rough throughout the entire RPM range with the cam timing off but Birddog from this forum insisted I check as he experienced similar symptoms with an engine with the same issue. BIG high five to Birddog for his persistence in having me check!
Now at least we've got the problem identified and can work on the solution....will be chatting with Superior first thing Monday morning.
Thanks to all those that provided experence, insight, and encouragement as I worked through a frustrating couple of months!
Chris Engler, Greene, NY
RV 8 Completed and Flying (N184CE), Showplanes Fastback and Cowl, Barrett IO-360; Dual GRT 10.4 HXr
Kitfox 7; Rotax 914, Built and Sold
VAF donation gladly paid through April 2022
Old 10-21-2017, 09:52 PM
DaleB's Avatar
DaleB DaleB is offline
The "Mystery of the Coughing XP-400"? I'm glad you solved it, but I was just a little disappointed that you didn't have any help from Jupiter, Pete and Bob.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 10-22-2017, 02:47 PM
Janekom's Avatar
Janekom Janekom is offline
Phew ! Well done
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2021 WITH A SMILE
Old 10-22-2017, 04:04 PM
I love the reference, but I bet only 1/100 RV'ers will get it.
And now I'm off to the airport in my chauffeur driven Rolls...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 10-22-2017, 04:46 PM
moosepileit moosepileit is offline
Had to google...
The Three Investigators is an American juvenile detective book series first ... as the " three investigators" are three boys named Jupiter Jones, Peter Crenshaw and Bob Andrews.
RV-6, bought from builder.
O-320, slider, carb, mags, FP
Old 10-22-2017, 06:42 PM
Steve Melton's Avatar
how in the heck did that get past the inspector?
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 10-22-2017, 08:26 PM
Steve - that's the million dollar question. As I noted in one of the previous threads on the topic, my engine was one of 5 "test cell" engines used during the development of the XP-400. The log book that came with the engine shows the following entries (paraphrasing):
1. New engine, test run and in a condition for safe flight
2. 150 hours in the test cell followed by a complete disassembly for inspection and replacement of wear items (bearings and rings). Reassembled in accordance with Superior procedures and work instructions and is in condition for operation.
3. 5 hours in test cell, certification that the engine was manufactured, inspected, and tested in accordance with Superiors Procedures and Work Instructions, and is determined to be in a condition for safe flight.
Each entry of the logbook was signed and certified by Superior.
The one that really has me scratching my head is the last one. My guess is the misalignment of the cam happened during the reassembly following the 150 hours in the test cell...but 5 hours of run time with the cam misaligned and this problem went undetected....I think not!
For those not familiar with the cam to crank alignment, the photo in my first post on this thread shows the cam gear on top aligned with the idler gear (note the "0" with a "dot" on either side). The crankshaft gear is the one on the bottom in the photo. Note that the "0" on both the idler gear and crank gear should align. On my engine, it's clear that the crank is misaligned relative to the cam by one tooth. As a result, the valves are not in the correct position relative to crank (and piston) positions.
Old 10-22-2017, 08:38 PM
birddog486 birddog486 is offline
I'm glad you've found the smoking gun Chris. When I read your initial post on your engine problems, it really took me back to all the frustration I went through when I was in the same position.
When you get some time I think it would benefit all the VAF future readers if you put the pic of the cam timing into your other post in case someone has the same symptoms in the future.
BTW my engine with the same problem was a carbed 0-320 on a Cherokee 140.
Travis
Old 10-22-2017, 08:52 PM
Good point Travis....I added a post to the old thread showing the misaligned cam.
Thanks again....would not have found this without your advice! I hope we can catch up in person some day....dinner will be on me!
Old 10-22-2017, 09:00 PM
BillL BillL is offline
Bill
RV-7
