Old 10-04-2017, 12:16 AM
FloMo14Builder's Avatar
FloMo14Builder FloMo14Builder is offline
Default Debur chatter
This is the result I get when i give my Avery speed deburring tool a 360 around a drilled hole.
This is a #40 drilled hole deburred and then dimpled on DRDT-2. Dimple was done to improve visibility of the jagged edge of the deburred hole.
I have tried using light pressure and heavy pressure fast and slow with similar chatter. Do I just need to buy a new 3-flute cutter? This tool was purchased new (in 2007) and has only been used on about 100 or so holes. If this is normal and I am just looking too close, I will be thrilled with that answer.
I am seeking your collective advice as I am now frustrated before I have even started (this is a piece of scrap from a 2007 Oshkosh sportair workshop that I was using to experiment on this afternoon). I have also been having some issues with my drilled holes not being round, but hopefully I solved that with a new set of drill bits.
FloMo14Builder - KG5VAC
Shop - Complete
Practice tool box - Complete
Practice Airfoil - Complete
Emp Kit - Building Vert Stab!!! WOOHOOO
Old 10-04-2017, 02:52 AM
jrs14855 jrs14855 is offline
Default deburring
1/4" shank 3/8 diameter 100 degree countersink, six flutes. MSC supply or industrial hardware store. If you can't find a handle for it make one. I can't find a source for the handle I have had for years. I used to be a fan of single flute countersinks for deburring but got over that a long time ago.
Old 10-04-2017, 04:07 AM
leok leok is offline
Chatter results from a cutter that repeatedly digs in, breaks loose, digs in, breaks loose. etc.. It is a harmonic with the machine (you) spinning the tool or work piece.
There are lots of ways to address this, but often the easiest is to change the cutter speed. Try spinning the tool faster or slower while adjusting pressure.
The tool can also have the tip of the blade ground to an angle that adds to chatter. In that case I have sometimes had success 'breaking in' the tool by deburring a few holes in steel. Tools will change over their life, depending on the wear, chattering only when fresh or more typically when forcing a dull tool.
Otherwise replace with a different brand/batch tool to find one that works for you.
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
Old 10-04-2017, 06:35 AM
snopercod's Avatar
These work great and never chatter:
(2020 dues paid)
Old 10-04-2017, 07:22 AM
rv7charlie rv7charlie is offline
Listen to Snopercod....
Old 10-04-2017, 07:52 AM
BillL BillL is offline
+1 +1 Just don't use them on fiberglass - even once.
Bill
RV-7
Old 10-04-2017, 08:09 AM
cczarnik cczarnik is offline
+2. I got the little one from Cleaveland. Wasn't a fan using it in the drill press or by hand. But a cheapie electric screwdriver from lowes is the perfect speeed, 2 turns and done. Press was too fast to cut well.
Chuck
7a emp complete, wings underway
VAF Dues paid - 2018
Old 10-04-2017, 08:33 AM
Mudfly Mudfly is offline
I like those for deburring as well. However, from my experience, they require much less pressure than the other deburr bits. Too much pressure/turns and the hole will be countersunk instead of deburred.
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2021 VAF Donation
Old 10-04-2017, 09:13 AM
sblack sblack is offline
slow the speed way down
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 10-04-2017, 11:10 AM
Offset handle to turn it is all you need. Power will almost always cut too much with any of the bits.
