Old 01-13-2017, 06:40 PM
Steve Melton's Avatar
Default found oil on the floor, grounded
I had been weeping some oil at the front end and had contacted Superior with pictures but it was inconclusive until today. I walked into the hangar and found oil on the floor and more on the cowl. I am grounded.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 01-13-2017, 06:50 PM
sbalmos's Avatar
sbalmos sbalmos is offline
Front crank seal?
Scott Balmos - RV-9A N112SB
Cincinnati, OH, KHAO
Old 01-13-2017, 06:55 PM
I don't know. There is also an o-ring on the constant speed prop. Suspect it is a front crank seal or the constant speed prop seal.
Steve Melton
Cincinnati, OH
DavidAhrens DavidAhrens is offline
Default Oil leak
Not good! Not trying to be funny but with that much oil leaking shouldn't be hard to find. Looks to be maybe Propeller to crankshaft area which in sealed via a O-ring. Also appears to be a Whirlwind Propeller?
Old 01-13-2017, 06:59 PM
sbalmos's Avatar
I couldn't remember if you had a CS prop or not. I'm betting prop seal, based on how it was able to pool on the edge of the air intake of the cowl. Crank front seal is too far back, but was the only idea if the prop was FP.
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Looks like the crank seal. Check to see if there's oil pooling inside the ring gear hub.
I replaced my split crank seal on my superior io360 at about year 2. I'm now in year 10.5 without it leaking. I replaced it with a non-split variety.
It's fairly easy to replace as I was surprised how it stretched over the ring gear hub.I sealed it with pliobond as recommended by the lycoming manual.
Update: I have a fixed pitch prop
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL
1240+ hours
Old 01-13-2017, 07:02 PM
It's fairly easy to replace as I was surprised how it stretched over the ring gear hub.I sealed it with pliobond as recommened by the lycoming manual.
I saw oil inside the ring gear hub but not on the fwd side.
Steve Melton
Cincinnati, OH
Old 01-13-2017, 07:04 PM
mine was on the aft side as viewed as in your last picture
1240+ hours
Old 01-13-2017, 07:06 PM
seems that I'll be replacing a front crank seal soon.
Steve Melton
Cincinnati, OH
Old 01-13-2017, 07:15 PM
gasman gasman is offline
If it is a crank seal, do check your crankcase vent......
have fun winding that spring...........
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
