Old 12-01-2015, 08:26 PM
scsmith scsmith is offline
Default doing things that don't need to be done
I'm most of the way through my condition inspection. This is the fifth one (flying six years). So I thought I would be extra thorough.
I pulled the wheels and cleaned and re-greased the wheel bearings. This was a waste of time. The bearings look like new. Compared to typical service exposure of auto hubs, our wheels are hardly ever used, hardly ever exposed to unpleasant environments. Wish I had not bothered.
Completely anecdotal, but I remember hearing of a study that was done by Greyhound Bus on whether it was better to periodically clean and re-grease wheel bearings, or just leave them be. The ones that were regularly cleaned and regreased had a higher failure rate. Suspected damage to grease from residue of cleaning solvents.
I pulled out my conical K&N air filter (it is in a ram-air housing similar to the Bower system but my own design, gets filtered air from the cooling inlet)
It looks like new. It is still pink from the oil saturation. I looked up on the K&N website for guidance on when we should be cleaning and re-oiling them. Some graphic pictures show when it is dirty enough to need cleaning. Mine was way cleaner than the 'clean' picture. Like I said, looks like new. Again, compared to automotive, very small environmental exposure. I even operate off of dry dirt fields occasionally. Wish I had not bothered.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 12-01-2015, 08:31 PM
Infidel's Avatar
Infidel Infidel is offline
Sometimes it's the piece of mind that makes a difference and whole heartedly, extends into each and very flight.
Old 12-01-2015, 08:34 PM
I was reading a maintenance document recently which recommended re-packing wheel bearings at least every 500 taxi/runway miles. I figure that is probably 2-3 years conservatively for me.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-01-2015, 08:47 PM
flyboy1963's Avatar
Default re-packing= good cleaning = bad!
in today's throw-away world, few have the equipment to service things.
a proper press for 'repacking' bearings that I used in an old garage had two discs that sandwiched the bearing. grease was slowly injected from the top centre of the bearing, and the old grease & contaminants were forced out.
no solvents involved, and thus no 'de-greasing' occurs....just MORE greasing!
We often slapped a different brand or better grade of grease in the gun, and you could see the new colour oozing out of the bearing cage, so you knew you'd gotten the job done!
I agree that much of the recommended maintenance intervals need to be considered vs needless disassembly.
obviously if you get your wheels wet, dirty, and run them for hundreds of miles annually, you want to thoroughly inspect and service as needed.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 12-01-2015, 10:47 PM
So Vlad should repack 'em every two weeks?
It seems to me that with lighter use, hangar protection, warmer temps, no salt water exposure, etc. that a repack every 2-3 years would be sufficient. I plan on at least jacking up the wheel, making sure it rotates freely and has no play at every inspection.
Doug
RV-9A "slider"--sold in July 2021
Donation made for 2021
Old 12-02-2015, 07:04 AM
Again an anecdotal reference... I recently pulled the wheels on a certificated aircraft, ostensibly to change the tires but also to repack the bearings. It's a good thing I did as one of the seals had cocked off to the side and was starting to get chewed up. It wasn't visible until I had the wheel completely removed. Sometimes the repacking of wheel bearings is incidental to their inspection. So far I've found that in light service like that which most of our aircraft see, every couple of years isn't a bad frequency of inspection. If a problem is once detected and corrected, the inspection frequency needs to bump up in order to provide increased vigilance to limit the possibility of recurrence.
Old 12-02-2015, 08:57 PM
simpkinsona simpkinsona is offline
Default Wheel bearings
I regrease only when I remove the tires to flip them or replace them. Works out to every 18 months or so. I don't clean them, just wipe off the dirty grease and add new by packing. They don't look like they need servicing but since they are out anyway I do it.
-Andy
Andy Simpkinson
RV-9a Subaru engine.
Old 12-03-2015, 04:29 AM
Eldo Eldo is offline
Default The Waddington Effect
Could this possibly be an example of the Waddington Effect??? I have seen this occur in the Airlines and General Aviation. I'm not advocating neglecting maintenance, just something to think about!!!
http://blog.aopa.org/opinionleaders/...ington-effect/
Eldo Nova
RV-6A flying - 60 Hours!
VAF paid in Cash
52F - Two rows over from the Van Cave
Old 12-03-2015, 06:26 AM
Steve Melton's Avatar
-Andy
me too, I just add new. no solvents.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 12-03-2015, 06:57 AM
n700jl n700jl is offline
Thumbs down "doing things that don't need to be done" WHAT!!!!!
This has to be one of the most uneducated post that I have read on this website! The one reason that we do a condition inspection on our airplanes once a year is to find something wrong! If you don't find something wrong then you are not looking hard enough! To suggest that something does not to be inspected is a complete failure on the owners part! How do you know that the wheel bearing is a condition safe for operation without pulling it? This is a total disrespect for your own and public safety. And to make the comparision of an RV to a Greyhound bus is the most ridicoulous thing that i have ever heard. What else did you just bypass on the inspection? Maybe you should hire a qualified A&P to inspect you airplane next time. I know that he or she will find something wrong with it, that will need to be corrected! I know doing wheels and brakes and repacking wheel bearings is a dirty time-consuming job. but lets move forward in aviation not backwards. Learn from other peoples mistakes and don't repeat problems that have happened in the past. And BTW! You should always, and I mean every year be "extra thorough"!!! You and your passengers life depends on it! Good day sir!
Jon Hubbell
RV-6 Flying IO-320X tip up 500+hrs G3X 2004 Oshkosh Outstanding workmanship award, 2004 Sun N Fun Best Workmanship 2006 Sun N Fun Outstanding Aircraft
RV-10 Flying IO-540-C4B5X 500+hrs G3X 2011 Bronze Lindy Award Winner
"Negative Ghostrider the pattern is full"
