w/a Donation
VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Main > Safety
Old 04-09-2015, 05:44 PM
Default Stay away from RTV near fuel
The NTSB this week released the probable cause of an RV-10 crash (I'm not saying where nor who because I don't want to open that can of worms and have people miss the important point) last year in which two people died.
There were two important takeaways.
(1) Don't use RTV* in a fitting in the fuel line.
(2) If someone with lots of experience and knowledge says "don't do that", then don't do that.
* Or Teflon tape.
Carry on
Bob Collins
Working on RV-12iS avionics
Professional Grandfather
St. Paul, MN.
Old 04-09-2015, 08:47 PM
Sig600 Sig600 is offline
What was the use of RTV? We're they trying to fix a leak or a bad flare?
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 04-09-2015, 09:19 PM
aerhed aerhed is offline
Floscan has pipe thread. You can see RTV used for the threads and some stuck inside the Floscan. No further comment.
Actual repeat offender.
Old 04-09-2015, 11:01 PM
A little smear of Loctite 567 would've been perfect.
Doug
RV-9A "slider"--sold in July 2021
Donation made for 2021
Old 04-10-2015, 05:51 AM
Walt's Avatar
Walt Walt is offline
A good example of how "it's what you don't know that will kill you". Chances are the offending substance was also used upstream on the fuel valve as the blockage was in the inlet of the FF xdcr line.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 04-10-2015, 05:58 AM
BillL's Avatar
BillL BillL is offline
I saw an engine oil pump that had ingested a slug of silicone RTV and it fractured the housing caused an engine failure. Oil pressure was high enough not to trip the pressure switch, but not enough to lube the engine.
RTV is only to be used in rare, very rare, situations for engine related sealing. And sparingly if used at all. Slugs of excess are just one of the failure modes, but is at the top of the probability list.
Bill
RV-7
Old 04-10-2015, 07:19 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
I can't think of a case where RTV would be ever indicated FWF. AN fittings are assembled dry and NPT fittings (like the one on the fuel flow sensor) require an aircraft-grade thread sealant like Tite-Seal. Where would RTV be the best approach anywhere FWF?
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
Old 04-10-2015, 07:32 AM
Mike H Mike H is offline
It is very saddening to learn that something so simple and obvious to most caused loss of life.
Regarding other comments stating to never use Teflon tape on threads. There is a type of Teflon tape made specifically for fuel and oil use, and I have used it many times on aircraft. Yes it can cause blockages is it is applied incorrectly, but so can Teflon pipe dope.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 04-10-2015, 07:48 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Anywhere FWF? Sealing various areas on the baffles comes to mind...
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 04-10-2015, 08:55 AM
Sorry, I meant on the engine. I know you can use it to secure wiring, plug holes, provide chafe protection, etc. Even then you need to be careful of which product you're using and the substrates on which you're using it.
