Old 05-12-2014, 07:17 PM
crabandy crabandy is offline
Default RV-7 cowling exit bump
Seeing other posts on VAF has motivated me do do some smoothing on my RV7 O-360 cowling outlet.
I can make it two ways, first is more of a bump on the bottom of the firewall. Screws/ nutplates on the bottom of the firewall and riveted to the firewall.
Poster board mock-up:
Choice #2 is more of a ramp directing air into the exit. Screws/nutplates for the bottom and adel clamps to the engine mount for the top.
#1 is more permanent leaving less room for experimentation than option #2. Hoping to start cutting some metal tomorrow and appreciate any input.
Thanks!
RV 7 590 hours and counting
21 donation done
Old 05-12-2014, 08:11 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Looks a lot like mine! Just be glad you don't have the -A model! It was a pain to get the curved aluminum in there without looking horrible. It ended up looking pretty good and has held up well over the past year.
Make sure to report back with your results after a test flight.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 05-12-2014, 08:57 PM
What were your results? Did you make the bump or the ramp?
21 donation done
Old 05-12-2014, 09:34 PM
BillL BillL is offline
Here is what I am doing. Ready for some screws so it can be removed. I just installed it before mounting the engine so riveting would be easier. I hope it will work
I made a hole template to make it easier to construct air management radius when the time comes.
Bill
RV-7
Old 05-12-2014, 09:47 PM
glenn654 glenn654 is offline
All of the exit ramps I have seen have open ends, do any of you think the ramp would be any more efficient if the ends were closed as much as possible?
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 05-13-2014, 06:43 AM
DanH's Avatar
DanH DanH is offline
Andy, choice 1 or 2 is probably a matter of convenience. Either way, I'd suggest that you fabricate from stainless sheet and extend it 12 inches aft of the firewall, over the aluminum belly skin.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-13-2014, 08:00 AM
airmel's Avatar
airmel airmel is offline
Default My "firewall fairing" -
It is .025 aluminum and the nut plates are on the fairing instead of the firewall.
FWIW: My husband has been flying with one similar to your option 2 on his 6 for many years and has not had any issues with the skin just aft of this area. He recently changed to one like option 1...
Melinda Harrill
Flying my RV-7!
Barrett Precision Engine - Superior IO-360 with AFP FI
Garmin Panel - All touchscreens
Old 05-13-2014, 09:20 AM
krw5927 krw5927 is offline
I've been considering this mod. Does anyone have actual before and after data on temps and/or speeds?
Kurt W.
RV9A
FLYING!!!
Old 05-13-2014, 09:46 AM
DanH's Avatar
Originally Posted by airmel View Post
[IMG] My husband has been flying with one similar to your option 2 on his 6 for many years and has not had any issues with the skin just aft of this area. He recently changed to one like option 1...
Extending the fairing, in stainless, is a fire protection measure.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-13-2014, 10:31 AM
Thanks for the replies, I made the drive to airparts and picked up some .017 stainless from their scrap bin. I like the fire protection.
Melinda, is your fairing only attached at the bottom? The tension in the curve keeps it from rubbing on anything...
21 donation done
