w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 03-30-2005, 07:46 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Lightbulb Building Tip - Fuel Tank Vent Line
Here's a tip for running your vent line on your fuel tanks that keeps the line out of the cockpit, reduces the number of fittings, and simplifies the installation.
This is a picture of my wing upside down. Inside the root, I ran a double loop of 1/4" aluminum tubing to a AN919-6D reducer fitting that I Prosealed to the skin. The 3/8" end has been sanded smooth using an electric drill and a bench grinder. The end has been cut at a 45 degree angle and rounded.
Many of the Rocket guys are using this set up and it works great. The double loop prevents most, if not all, fuel leakage from a full tank in the hot sun. As usual, all disclaimers apply. YMMV.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 03-30-2005, 08:53 AM
Interesting - with the top of the fuel in the dihedral oriented tanks placing fuel above the top of the loop it does cause some concern. Do you extend a vent line on the inside of the tank from the fitting to the high point in the tank at the outboard end?
Old 03-30-2005, 10:09 AM
f1rocket's Avatar
Yes, the tanks are built with the vent line running inside the tank all the way up to the top side of the farthest outboard end.
The only thing the line in your cockpit does is create a loop of line higher than the tank, thus preventing fuel expansion from pushing fuel out of the vent. The doule loop of line does the same thing effectively.
Randy Pflanzer
Greenwood, IN
Paid through 2043!
Old 03-30-2005, 11:29 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Is it really working?
What did they use to determine this? Did they try flying in several different
attitudes with a chase plane to ensure no fuel was flowing out? I guess if
your tank was still off the wing you could move the thing around to see
if anything leaks.
This looks a lot simpler than the way I did it, for sure.
Mickey Coggins
http://www.rv8.ch/help-people-in-ukraine/
Old 03-30-2005, 12:40 PM
Mel's Avatar
Mel Mel is offline
Let's play "devil's advocate" for a minute. What happens if you are forced to park with one wing low with full tanks putting the fuel level above the inside vent opening and also above the loop? Now with heat expansion fuel begins to flow through the vent line? Would this not creat a siphon effect?
Mel
Old 03-30-2005, 12:52 PM
PJSeipel PJSeipel is offline
For a siphon effect, air would have to be able to get into the tank to replace the fuel going out. I'd guess you'll lose whatever fuel the expansion pushes out of the tube and that's it. Same situation as if you ran the tubing through the cockpit.
PJ
Old 03-30-2005, 01:02 PM
f1rocket's Avatar
if anything leaks.
Over 30 Rockets flying with this set up. The Rocket plans show this as the standard way to vent the tank. I thought the RV folks might be interested in using this. If not, that's okay by me.
Randy Pflanzer
Greenwood, IN
Paid through 2043!
Old 03-30-2005, 02:09 PM
rv8ch's Avatar
Default Good tip
That's good enough for me. Unfortunately this tip will have to wait
for my next RV, since I've already done vents on my 8.
Thanks for sharing it with us, and please feel free to send over
any other rocket tips!
Mickey Coggins
Old 03-30-2005, 04:39 PM
Radomir's Avatar
Radomir Radomir is offline
is this how they do it on RV-10? I thought I saw something like this on teh -10... but may be wrong..
Radomir
RV-7A sold
RV-7A bought
Old 03-30-2005, 04:40 PM
Davepar's Avatar
Davepar Davepar is offline
That is tempting. I haven't even drilled the hole in the side of the fuse for the vent line yet. Hmmm...
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
