Old 10-02-2013, 06:54 PM
DanH's Avatar
DanH DanH is offline
Default Baffle Rubber Done Perfectly Wrong
Walked past this Cessna in a maintenance hangar the other day.
The only baffle rubber not pointing the wrong way apparently never touches the cowl at all. However, some genius did give it a tuneup with a spray can of silver paint
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-02-2013, 06:59 PM
Snowflake's Avatar
Well, it probably starts out pointing the right way... Those Cessnas fly at such a blisteringly fast speed, they couldn't hold up and just flipped over the other way...
On the other hand, maybe this is why it's in the maintenance shop in the first place...
Rob Prior
Old 10-02-2013, 08:51 PM
BillL BillL is offline
" . . . but it was signed off by an A&P!? "
Just sad.
Bill
RV-7
Old 10-02-2013, 09:40 PM
AlexPeterson's Avatar
The blue paint on the starter ring gear is a nice custom touch too.
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
Old 10-02-2013, 10:37 PM
rvmills's Avatar
rvmills rvmills is offline
But Alex, c'mon...that paint it so well done!
The things we didn't know that we didn't know as renters, eh!
Bob
(learning more everyday!)
Bob Mills
RV-S6 "Rocket Six" N49VM
Cross Country-Marshall Field (07TS)
Georgetown, TX
President/Sport 49, Sport Class Air Racing
Trustee, Formation Flying Inc (FFI)
Old 10-03-2013, 06:15 AM
MarkW's Avatar
MarkW MarkW is offline
At least they did a nice job of sealing around the crankcase.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 10-03-2013, 07:14 AM
airmel's Avatar
airmel airmel is offline
Default Well, since...
That's it! It IS pointed the right way - the high pressure area is below and the air comes up and exits through the front!!
Melinda Harrill
Flying my RV-7!
Barrett Precision Engine - Superior IO-360 with AFP FI
Garmin Panel - All touchscreens
Old 10-03-2013, 07:29 AM
Weasel's Avatar
Weasel Weasel is offline
Default Winter Opps
It is fliped that way to bleed off excess cooling air to help the CHT's get up into the normal range as it is getting cooler here in the south
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1700hr counting
RV-10 N7631T 820hr Sold
RV-8 700+hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 10-03-2013, 07:40 AM
DanH's Avatar
Clearly the bad baffle sealing has been found acceptable during several past annuals. This sort of non-sealing is very, very common in certified GA aircraft, which is why I don't give much weight to RV builder statements like "My CHT's are high, but my mechanic has checked the baffles and says they are fine". You've seen my usual response: "Post pictures".
Please allow some clarity; I don't wish to paint all A&P's with a broad and ugly brush. However, I do have a question, and it's just as applicable to RVs as any other bird. Is this or is this not considered an airworthiness issue? Is the mechanic who signs off such an obvious fail putting his license at risk? Or is this just something a mechanic must sell to an owner to get it done?
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-03-2013, 07:56 AM
newt's Avatar
newt newt is offline
What'd you say to the A&P, Dan?
- mark
[ Paid up on 16 Jul 2021 ]
RV-6 VH-SOL
