Keep VAF
Going
01-10-2021, 03:52 PM
Stroke of VANS prop cable?
Hello
Trying to get the parts order together for the FP to CS upgrade. Now I need a longer prop cable (due to 320 engine mount which is 2" longer.
ACS have the A-1760 VANS RV CUSTOM CONTROL CABLE option for this. But to fill the order, I need the stroke.
Does anyone have the prop cable still on the bench to measure?
2-1/4" or 2-1/2" is the question.
Stand. P920-032 Gov.
Thanks alot!
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
01-10-2021, 08:23 PM
They are nominally 2 1/8". A cable with a 2 1/4" stroke will work very well.
Having had to change a few after 500 hrs or so, I would recommend getting a high-quality McFarlane custom cable instead of the Vans/ACS cable, although for the prop control it is less of an issue because you likely will not be routing it near any high temperatures. (unless you have a forward governor mount).
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
01-10-2021, 10:42 PM
I curious....can you tell us more about the quality comparisons that sets the McFarlane products above the others?
01-10-2021, 11:42 PM
VAF Moderator / Line Boy
Well, for one, all of the Van’s cables (made by Cablecraft - or at least they used to be....) came with a label saying “Not for Aircraft Use”!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
01-11-2021, 06:09 AM
Paul
Interesting ... who does the cable for ACS? ACS is also supplying cables made to be used in Van's aircraft's.
Dominik
McFarlane
Totally agree.
@Dominik - let me know what you need. I went through many cycles of custom cables before I got them just right. Yes, I probably overdid it a little bit, but I wanted it to be perfect. I have lots of cables that didn't quite work for me and I'll be happy to send them to you to look at and to test - both Van's and McFarlane.
01-11-2021, 02:23 PM
The ACS cables are the same as Vans. The liner does not seem to withstand high temperatures very well, and over time, the cable gets very 'not smooth', catches, binds. One symptom I noticed was that it would feel rough when cold, and get smoother when hot. Some have reported them binding altogether.
The McFarlane cables are VERY smooth, and are designed for high temp environments, and last at least until TBO.
I just noticed that McFarlane is now a VAF advertiser, see the side panel over here <------.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
Hobbs 635
01-13-2021, 06:19 AM
Thank you for all the information!
I'll know that McFarlane is better, but these are way more expensive. Also the look then would be different for the prop only. Cant afford to change all three.
On my Throttle and Mixture cable, I have a fire sleeve to protect them FWF a bit against heat. So far 300h and still working fine. I' will go with the ACS Version and 2-1/4" stroke.
Dominik
Thread Tools |
Display Modes |
