w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 03-15-2022, 12:37 PM
Bob Y Bob Y is offline
If the stall switch is the same on the 9 as the 12, the stall vein operates a microswitch, which is adjustable via screws. To reduce the chance of moving the switch out of a ligament, I insert a thin metal strap - actually a piece of the banding material from one of the shipments - in the opening between the vein and the wing cutout on the side in which I want to bend the vein. If it does get out of alignment, you’ll have to remove the access panel below the stall warning vein, loosen the screws on the microswitch, readjust and retighten the screws. See KAI section 16, attached.
Click image for larger version
Bob Y - builder 12iS
N569TT first flight 2/9/2020
#121047
Old 03-15-2022, 12:49 PM
Sportquattro's Avatar
Sportquattro Sportquattro is offline
Thanks Bob that sounds like a good method, I don’t suppose you’ve any knowledge of how much adjustment needed for a 5kt ish adjustment? I’m guessing a degree or two but any inside knowledge most welcome
Nige
Nigel Heald
RV9a G-CSAM @ Exeter EGTE UK
Finally finished
Old 03-15-2022, 02:26 PM
RandomSquawk RandomSquawk is offline
My copy (rev 13, Oct 2020) has same typo.
Crazy coincidence that I happened to notice this same detail I wasn't even looking for, on the same day that someone else replied to a 12 year old thread.
Old 03-15-2022, 03:04 PM
No, sorry, it’s pretty much trial and error. On my first flight, mine was going off the 70 kts! Quite annoying.
#121047
Old 05-11-2023, 03:24 PM
dcflyer84's Avatar
dcflyer84 dcflyer84 is offline
Had to replace my stall warning microswitch; obtained new one from Van's. Remounted the bracket in the exact same position. Flew. Warning came on too early; adjusted down per this thread. Multiple adjustments have been required, making very small bends. After this last adjustment, it starts going off at liftoff and stays on the entire flight. ??!?$%?*
Ideas from the collective?
I'm thinking the vane tab may have bent up/curved inside the wing, thus activating the switch arm too soon?
Old 05-11-2023, 06:51 PM
NinerBikes NinerBikes is offline
Adjust tab UP to increase the speed the stall warning indicator comes on, ie at higher air speed = greater safety margin.
Adjust tab DOWN to lower the speed at which the stall speed indicator comes on, ie at lower air speed with less margin of safety between warning and stalling and possibly falling out of the sky= thinner safety margin.
VAF dues paid 2022
RV-12, KWHP based
"Time to Spare, go by Air."
Old 05-11-2023, 08:38 PM
The method I described in post #11 works for me. Inserting something in the gap between the stall-warning vein and the edge of the wing cutout prevented the vein from bending inside the wing and keeps the bending force off the microswitch.
#121047
Old 05-12-2023, 08:03 AM
dcflyer84's Avatar
I had reviewed the thread before I did anything the first time but thanks to those who clarified. Used a shim to hold the tab in place within the slot and adjusted again. Worked better; not going off the whole time anyway. Will keep tweaking.
Old 05-24-2023, 05:53 PM
JwWright57 JwWright57 is offline
You could (if you have not) install and calibrate the AOA system and then forget about the stall warning. Most would say its a lot better than the stall warning.
Jeff Wright, Charlotte NC
Rv-12is with 912is and Dynon system.
Certified Aug 2021
Dues paid 2022
