Old 06-13-2021, 08:27 AM
wirejock's Avatar
wirejock wirejock is offline
Default Bend
I made the flare first. The extra length (1/2") didn't make much difference.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 06-13-2021, 09:19 AM
Mark Jackson Mark Jackson is offline
Default Flaring bent tube
I was able to flare the end. The test version was acceptable albeit not too pretty. I was using scrap tubing and nuts so forgive the picture quality.
Steps:
  1. Make the bend.
  2. Install the sleeve so about 1/16 or more is out the top of the sleeve.
  3. Wrap the tube & fitting in masking tape.
  4. Install the fitting in the flaring tool so the body is in the clamp and the thick collar is in what is normally the flared area.
  5. Clamp the yoke assembly in a vise so the flaring cone is just above the tube end.
  6. Slowly (and with lube) screw down the cone.
My real takeaway from this is to do a better job planning. I think in each case I could route the tubing in a way that doesn't require these whacky bends.
I have ordered by second 12' of tubing from Vans. Hopefully this will go better.
Click image for larger version
ID:	12574  Click image for larger version
ID:	12575  Click image for larger version
Mark Jackson
Houston, TX
RV-8 in progress
Old 06-13-2021, 09:46 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Originally Posted by Mark Jackson View Post
My real takeaway from this is to do a better job planning. I think in each case I could route the tubing in a way that doesn't require these whacky bends. ...
This was exactly what I learned from a very similar situation.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 06-13-2021, 11:48 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I wonder if a spring tube bender would work here?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-13-2021, 12:09 PM
The issue isnt necessarily the bender, but the width of the flaring dies. I have 3 tools. A Parker Rollo flare, a Rigid RFT37 that has a narrower flaring bar and an Olsen roll flare machine. Thats only if you bend the tube first. The big trick is flare the tube first, trim 1/2 of the tail of the 819 sleeve so it just protrudes out the aft of the nut, install the sleeve and nut. I made a threaded mandrel the screw into the nut, and rests against the fulcrum on the hand bender. Biggest trick is to cut a relief slot in the bend die at the 0* mark so the sleeve and nut can rest in that space. It effectively moves the flare aft towards the bend.
With our production flare machine we had special dies made with a narrow grip range and an open relief in the aft section of the die so a pre-bent 90* tube can be flared.
Tom
Name:	364FHA modified bender.jpg
ID:	12584  Click image for larger version
Name:	hand bender close up.jpg
ID:	12585  Click image for larger version
Ridgeland, SC
Old 06-14-2021, 09:43 AM
kiljoy's Avatar
kiljoy kiljoy is offline
I ran into the same problem making a couple of fuel line pieces. Found that I needed a minimum of 1.5" straight line to make the flare and hold the flange on. As long as whatever needed that line could have 1.5" of straight line leading into it it was fine.
Dues paid (2020)
RV-14 #140394
Empennage - done(ish)
Wings - done(ish)
Fuselage - done(ish)
Finishing Kit - Somewhere in there
YouTube Build Channel
