Old 05-20-2021, 06:00 AM
BillL BillL is offline
I got a 10 ton of similar design off of eBay and it was adequate. The die numbers are not accurate but this one had dies large enough. The hex dies are not pretty precision, but do a good looking job. It has been used for making battery cables for several other projects too. Just make sure it ships from USA and can be returned. Lower cost tool too.
Be sure you search/find a table for pull force tests of wire crimps. The #2 is ~500 lbs IIRC. I tested with a lever and a biped hanging weight and was satisfied the crimps were sufficient to meet industry specifications.
I do crimp twice, 90 deg apart to ensure the parting line extrusion is eliminated.
Battery Cables USA for non aircraft, offers good cables, closed/welded terminals, heavy shrink tubing, premade parts at very reasonable prices and shipping. Very fast shipper. I am a very satisfied customer.
Bill
RV-7
Old 05-20-2021, 06:11 AM
lr172 lr172 is online now
that is what I used. NO way I would spend 100's of dollars to crimp a few connectors.
Larry
Old 05-20-2021, 10:54 AM
kaa kaa is offline
Originally Posted by rmartingt View Post
I have many 2 and 6 gauge wires (dual bus system) and use this for crimping those: https://www.amazon.com/dp/B00ZA2P3XM/
It's very nice being able to do it right there in place and I've already redone a couple things as I've progressed. I've also used it on my car (had a battery terminal break).
I got a similar one from AS: https://www.aircraftspruce.com/catal...?clickkey=7268. It needed a small modification to properly fit some of the lugs, but overall worked adequately.
Definitely better than the crimps I removed for the upgrade - those pulled apart with just a firm tug. 10 years in service...
Konstantin Azarov
RV-7
Old 05-20-2021, 11:08 AM
Well Larry said big cables, so we use this----yeah kinda overkill but if you have it, might as well use it
Tom
Click image for larger version
Name:	CC60 crimper.jpg
Ridgeland, SC
Old 05-20-2021, 11:15 AM
Ralph Inkster Ralph Inkster is offline
Probably new in the 1930's.
I think I'm getting more use of these tools than my Grandfather did.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 05-20-2021, 12:50 PM
wirejock's Avatar
wirejock wirejock is offline
Default Crimper
Thanks everyone. All good advise.
The auto shop or borrowing are great but, I like having the tool on hand when I need it. Who know what I may need later. This isn't terribly expensive.
I think the Amazon model is the one.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 05-20-2021, 01:10 PM
fl-mike's Avatar
fl-mike fl-mike is offline
West Marine has them in the store to use. Might check similar in your area.
Mike W
Venice, FL
N164WM
Old 05-20-2021, 01:44 PM
JDA_BTR JDA_BTR is offline
This worked well for me:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 05-20-2021, 02:23 PM
rapid_ascent rapid_ascent is offline
Larry,
I'm like you, I prefer to have to the tool. I bought this one off of EBAY.
https://www.ebay.com/itm/20328978517...temCondition=3
Just in case you need a source for AWG2 Tefzel wire I found this source on EBAY. https://www.ebay.com/itm/392296063002
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 05-20-2021, 03:54 PM
wirejock's Avatar
Originally Posted by rapid_ascent View Post
Larry,
The one on Amazon is 16 Ton for not much more.
I have all the wire. Using Welding wire North of the Firewall. #2, #4 & #6.
Larry Larson
Estes Park, CO
Disclaimer
