Old 07-20-2018, 07:29 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by Walt View Post
The Deutsch guns are the way to go, you could do 20 in the time it takes to do 1 with a nutplate jig
http://www.aircraftspruce.com/cache/...s/nutplate.jpg
I don?t see a price, but I am guessing that with a name like Deutsch, you could use all ClickBond nutplates And come out ahead - and save a LOT of time!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 07-20-2018, 07:32 PM
maniago's Avatar
maniago maniago is offline
Never used a nut plate jig. Just use a nut plate itself. On the M2, almost all are 6-32 screws so drill hole w/ #28 drill first, wind the nutplate down on the screw and drill the wing holes #40. Debur and rivet. Done. With the folding wing, I prob have 5-600 nutplates for stuff thats usually riveted.
For those of you worried about wallowing out the wing holes, forget your worries (within reason of course). Nut plates torque against the rivets in shear, not strain, so as long as you fill the wallowed hole with your squeezed rivet, it wont go anywhere - ever. You really only need one wing rivet to secure the nutplate, so the second one is just "turning" insurance - but good to have none the less.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y
Old 07-20-2018, 07:40 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by David Paule View Post
Gee, I just use another nutplate. Put a screw or a cleco in to hold it, drill one rivet hole. Drop a cleco in there, drill the other. Once in a while, rivet the nutplate to the airframe and use another one as the tool.
Why bother with a special tool?
Dave
Originally Posted by rocketman1988 View Post
I just use a nut plate. Take a standard machine screw, put a nut on it, drill the screw hole, thread screw into nut plate a couple of threads, run the nut down to hold it, drill away...
No muss, no fuss, no wrenches required...
Originally Posted by NYTOM View Post
I built my whole plane using a a nut plate drilling jig called a nut plate. I didn?t even know there was such a thing. Seems llke the holes on the jig would get larger and sloppier the more you used it. Just using the nut plate your going to install seems like the easiest, most accurate way to go. Just make sure you cleco the holes as you go to keep it aligned. Never had any problems this way. Oh no, maybe all of mine are wrong.
Ditto on all counts. Just another tool that will collect dust. Besides, there will be places that jig won't fit and you will use a nutplate and screw anyway.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-21-2018, 06:05 AM
rzbill's Avatar
rzbill rzbill is offline
OMG. Yes, you can walk uphill to school barefooted in the snow.
Of course you can use a nutplate and cleco instead of a jig. Did that early in construction.
Jigs are faster and easier to keep the new holes oriented the way you want.
A must have? Certainly not. Nice to have. Yup.
Bill Pendergrass
ME/AE '82
Old 07-21-2018, 06:34 AM
Walt's Avatar
Walt Walt is offline
Only $4565, this drill all 3 holes at once so as fast as you can move it you can have a perfectly drilled holes. Wayyyy faster than clickbond.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1900+ hrs, New Titan IO-370, Bendix Mags
Old 07-21-2018, 06:42 AM
Ironflight's Avatar
But you still have to countersink for, and squeeze, rivets to mount a regular nut plate.
ClickBond - one hole, squirt adhesive, pull the fixture through the hole - done!
Paul F. Dye
Old 07-21-2018, 07:15 AM
BillL BillL is offline
https://www.yardstore.com/nut-plate-...-standard-518h
#6 and #8 - - -it will do single leg too. Some places they just don't fit, but then using one for a guide works.
NAS 1097 rivets
Bill
RV-7
Old 07-21-2018, 10:23 AM
Tom Martin Tom Martin is offline
I built three planes using the nutplates as a jig. Then I used a nutplate jig for the next 8 planes. It is a lot faster and more accurate in my opinion. I use just one tool set up for the most common #8 nutplate this works for all standard nutplates you just have to drill the centre hole out for larger screws.
Accuracy is as good now as it was when new.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 07-22-2018, 06:00 AM
Reflex Reflex is offline
After using the nutplates as a jig, I thought I'd try a jig so I bought one. As Mr. Martin said, it's a whole lot faster and much more accurate. It's one of those things I bought and thought, wow....why didn't I get one of these sooner? I now have 3.
Dues Paid for 2021
RV-14
Emp Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse Complete
Working on Finishing Kit
Old 07-22-2018, 06:36 AM
tswanson tswanson is offline
Thanks everyone. Although it sounds like the consensus it can be done without with similar results, I'm a big fan of having good tools if they make life easier at all. I'll get a couple ordered.
Thanks!
Todd Swanson
Tremont, IL
RV-7 Empennage in progress
