Keep VAF
Going
11-18-2020, 08:17 AM
ACK Activation
I had an unintended activation of my ACK Elt two weeks ago and got a call from the air force looking for me on a voicemail at the end of my trip. Somehow the ELT got activated on a dead-smooth flight and one of the best landings I have made. Until I read this thread today, I wondered how it could have gotten turned on...my remote panel for it is somewhat hidden by the bezel of my comm radio and the red LED would not necessarily be in my view while flying. I think the Cosmic Rays set it off  It has not happened since or previously.
Ed
Sonex/Corvair 2016 Finished, Sold 2020
RV-9A 2005 Purchased
IO-320 160 hp
Exempt but happily paid for 2021
11-18-2020, 09:30 AM
Good Intel on the suppressor
Some good Intel here on the suppressor..hadn't seen that before. I will look at that for my dilemma, as I don't want to keep having false trips, or buy a new one at this point. Just seemed odd I had no problems for 8 years.
Bill E.
RV-4/N76WE
8A7 / Advance NC
11-18-2020, 02:09 PM
Originally Posted by smt6
I installed the static suppressor after having many false alerts. It did nothing. The ACKs are junk. Buy an Artex
My ARTEX had false alerts on different days. Replaced with ACK-E04. Buy ACK, ARTEX are junk
My antenna is mounted internally, so the static buildup issue can't occur.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
11-18-2020, 06:33 PM
I had one FALSE ACK E-04 alarm after a smooth landing during engine shut down.
What upset me was the ACK E-04 FAILED it's 1-year 91.207(d) test and had to be returned to the factory. They replaced the transmitter for FREE but I did purchase a new battery that was NOT needed.
It appears that they may be using a "static sensitive" RF transmitter chip that now requires the static suppressor on the antenna. Now that I am aware that the transmitter can be damaged easily, I will use the ESD training I had at work before I retired when ever I do anything with the ELT.
What worries me more than false ELT alarms is my iPhone has TWICE called 911 without me touching it. Started airplane, went flying, and when I landed, I had a voice message from the 911 operator about 911 call from my number. 2nd time, I started airplane, and when I powered on avionics, the phone was ringing in my headset and 911 operator was at other end. There were several months and many flights between these two occurrences.
My iPhone now goes into airplane mode before I get in the airplane.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
11-18-2020, 07:57 PM
It must Gary or Gary’s plane causing all this! LOL
You’ll also note that there was no ESD testing claimed the table. Rather disturbing, because that is a very easy and fast test to run...unless you fail.
Mike W
Venice, FL
N164WM
11-25-2020, 01:00 AM
Originally Posted by jmra72a
Yes I had similar problems with mine. I called ACK and they advised it was water in the batteries or RF interference. My batteries were fine. A friend advised me to remove the ELT and wrap it in aluminum foil. Clamp it back in the holder making sure that the wrap was well grounded.
I did this 6 months ago and have not had a false activation since.
Give it a try.
As wild as this sounds, I did this...and so far so good. I’ve fought this subpar ELT for four years. Numerous calls from Air Force, Coast Gaurd, ect. If I’d have known all I had to do was wrap it foil...wow
2020 Dues Paid
11-25-2020, 03:48 PM
Originally Posted by Canadian_JOY
I'll second this recommendation that the ACK's are a substandard device.
My first recommendation remains the Kannad, despite their expensive battery pack replacement. Their in-service record is at the top of the pack.
The Artex comes next in line.
The ACK E-04 is at the top of my list of "do not install" equipment.
Totally agree. My ACK didn't pass this year. Only 3 years old. Bought the Kannad after talking to a couple of shops that do the ELT testing. Both said the Kannad fails the least of any. Also has a 10 year warrantee.
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
11-25-2020, 04:14 PM
I have ACK E-04 ELT, in phase one in smooth air in flight it activated, saturated all my comm frequencies. I installed the static suppressor ( Now at 120 hours and have not had 2nd occurrence.)
Keeping my fingers crossed.
Steve
RV10 - Flying (Jan 2020)
11-26-2020, 01:10 PM
i have had my hangar door transmitter set off my ELT, changed transmitters.
gary
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
