Old 05-30-2022, 08:06 AM
togaflyer togaflyer is offline
Default EI back up power (concept)
So this was a discussion I had with a buddy over breakfast regarding back up power for an electronic ignition. Off the shelf TCW has their backup battery, so this is about an inexpensive alternative. So the concept is:
Purchase a Dewalt 12 volt power station dock.
Wire it to a two position toggle switch so you can select normal power (also wired to the switch) or emergency power (comes from a Dewalt 12 volt 5 ah battery).
Mount the battery docking station in an accessible location for easy access so you can remove to recharge or check on the charge level (since the battery has a built in indicator).
TCW has a 3ah backup for 260 dollars. You could install a 5ah Dewalt backup for under 100 dollars. And since it is accessible and removable you could carry an extra battery and swap it out with a fresh one.
Really couldnít come up with a negative issue other then forgetting the battery is there and not checking the charge level. In some ways I think it provides even more redundancy since, theoretically, you could maintain a power source to the EI by replacing the system with a spare fully charged Dewalt battery.
Rich Gurr
RV 10 924RL
9A0 & FD51
Old 05-30-2022, 08:52 AM
Toobuilder's Avatar
I have measured the total system draw of a single SDS CPI system at 1.69 amps. Thats at 2700 RPM and 6 cylinders. Thats a pretty modest load, and there is a vast selection of low cost, lightweight industrial batteries that will supply spark for far longer than the fuel holds out. Easiest "emergency" power source is the existing ships battery. Just have a switch that is wired to hot in case you need to shut down the master in flight. Now if you think you are going to loose an alternator AND your battery in the same flight (besides having a very, very bad flying day), there are second battery options available that are simpler, lower cost and more robust than the Dewalt scheme. There is also the very light weight Monkworks pad mounted generator if you really need a robust way to keep the engine running indefinately.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
1940 Taylorcraft BL-65
1984 L39C - SOLD
RV-8 - SDS CPI - SOLD
Old 05-30-2022, 10:24 AM
DanH's Avatar
DanH DanH is offline
Even better, don't power an ignition via the main bus. Wire it battery direct.
...there are second battery options available that are simpler, lower cost and more robust than the Dewalt scheme.
Agree. Power draw is very small, as Mike illustrates. The EDIS-based system on my 4-cyl only pulls 1.08 amp at 2700. So, exceeding fuel capacity driving one ignition, even with the main battery and alternator both offline, only requires 4, maybe 5ah. That's just a small bike battery or similar. And it can be wired to remain charged without remembering anything, with a charge warning, and a push-to-test voltage indication under load.
Click image for larger version
Name:	Dual EI Wiring w Warning.jpg
ID:	26432  Click image for larger version
ID:	26433  Click image for larger version
Name:	IGN Volts Check.jpg
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-30-2022, 10:35 AM
1001001's Avatar
1001001 1001001 is offline
My friend's RV-10 has dual Lightspeeds powered by independent circuits wired directly to the main batteries (one on each battery). There are two circuit breakers in the back by the battery in case of a short in one of the wires, but other than that, the ignitions are always hot. Well, not technically hot, but always have power.
Old 06-01-2022, 11:45 AM
If it’s a new build I can see that configuration. But on a single battery set up on a flying plane, just kicking around a keep it simple set up.
Rich Gurr
RV 10 924RL
9A0 & FD51
Old 06-01-2022, 12:30 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
EarthX has a nice backup battery purpose-built for this kind of application: https://earthxbatteries.com/product/...ck-up-battery/
I installed one in my -6 a year ago.
Old 06-01-2022, 04:44 PM
DanH's Avatar
Originally Posted by togaflyer View Post
If itís a new build I can see that configuration. But on a single battery set up on a flying plane, just kicking around a keep it simple set up.
The illustrated second battery system for IGN#2 was in fact added to an already flying airplane when it was converted from Slicks.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-01-2022, 07:09 PM
sailvi767 sailvi767 is offline
I agree, the EarthX battery was purpose built for this use and not all that expensive.
RV-6 sold
F-1 Rocket
Old 06-03-2022, 09:46 AM
Other than the BMS, what does it have over a 60 dollar 5ah Dewalt 12 volt battery?
Rich Gurr
RV 10 924RL
9A0 & FD51
Old 06-03-2022, 02:07 PM
I suspect the battery portion is manufactured with a higher quality margin. All Lithium batteries are not the same. It also can self regulate charging input and will provide cautions if there is a malfunction.
One thing that should be mentioned is other EarthX batteries due not regulate charging input and need to be sized to the alternator.
RV-6 sold
F-1 Rocket
