Keep VAF
Going
01-24-2022, 08:45 AM
Air filter cover plate; air filter distorting ? Why?
I've had two air filters distort. The air filter medium is bent out of shape. The air filter cover plate that should hold the air filter in place cracked where the leading edge on the outboard side is bent up to screw in place to the baffling. I don't have my plans with me, as I am away from home for the next 3 months. Anyone know the part number for the air filter hold down cover plate? IO390 engine, standard Vans finishing kit baffling. Anyone else having a problem with their air filter getting distorted? Any suggestions about what to do? Thanks, JDW
Slow Build, Thunderbolt, HRT74 prop, TS Flightlines, Garmin IFR panel, Lemke interior, Aircrafter's Refinishers paint job. Based at KJGG
190 hours logged since October, 2020
01-24-2022, 09:06 AM
Backfires probably when starting.
01-24-2022, 10:22 AM
As Chris mentioned, backfire in the intake. Part # CB-00033 @$8
Multiple people have had this to happen
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
01-24-2022, 10:23 AM
CB-00033 Air Filter Frame Cover
Backfire most likely, as Chris mentioned.
Alex C.
2021 RV-14A: Flying as of 4/13/21 (~98hrs), and painted by Evoke Aviation on 5/18/22
1999 Cessna 182S - Sold
https://alex-rv14a.blogspot.com
01-24-2022, 11:54 AM
Air Filter hold down cover plate on order from Vans; THANK YOU FOR PART NUMBER
Roger, thanks guys, for the speedy reply. Part on order from Vans. Now I need to learn how to start engine without a backfire. JDW
01-24-2022, 02:18 PM
Many of these filters could be sourced locally; check local automotive supply stores.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
01-25-2022, 04:30 AM
Perhaps check your timing.
Glenn Martin
Windsor, Ontario
1941 Tiger Moth
2017 Waco YMF-5
RV-14 Kit # 140694 - First Flight June 22, 2021
RV-14 A - Kit Ordered February 8, 2022
2022 Dues Paid
01-25-2022, 05:31 AM
I have also seen it happen on shutdown if mixture control is not correctly adjusted to be not quite lean enough to do a full shut down.
Dennis Callaghan (X26)
- RV14 sn:140193 - Awesome airplane!
- donation 11/27/2021 * 2
01-25-2022, 09:14 AM
Excess horsepower deforming the filter?
RV6A in phase 2 as of April 2016
Donation made Oct 2021
01-25-2022, 12:15 PM
My -7 blew out a filter and it looked just like that ... after a backfire from too much priming.
IO-360 EFII Ignition
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
First Flight 7/17/2021!! 200 hours 6/22
 - Been there, Donated 2022
Thread Tools |
Display Modes |
