  #21
Old 10-04-2019, 08:26 PM
Gear Gear is offline
Originally Posted by gasman View Post
These...... https://www.harborfreight.com/6-in-d...igital+caliper will get you through your entire build for under $20.00.
Do not over spend for tools that you are not going into business with.
I bought one of those....stopped measuring correctly after 1 use. YMMV
Planning, planning, planning.......
VAF Donation 2020 ✅
Old 10-06-2019, 11:01 PM
jdog0411 jdog0411 is offline
Originally Posted by Vol88 View Post
I just found a Class Project inventory from 1/14/13. Here are the bag contents it lists:
Bag 1: AN426AD3-3 rivets .02 lbs
Bag 2: AN426AD3-3.5 rivets .01 lbs
Bag 3: AN426AD3-4 rivets .01 lbs
Bag 4: AN426AD4-4 rivets .01 lbs, 6 AD-41-ABS pop rivets
Bag 5: AN470AD4-4 rivets .01 lbs, 2 MSP-42 pop rivets
I found this today while inventorying a box of papers from the original builders of my "new" RV10.
Maybe it will match what you have. Regardless, have a blast building!
Thank you sir! I believe that does match whats in the kits I got. That helps a lot.
Parker, CO
RV-14A Under Construction
Empennage Kit arrived on 10/11/19.
Vertical Stabilizer DONE
Rudder DONE
Began Horizontal Stabilizer 01/28/20.
Horizontal Stabilizer DONE
Started Elevators on 02/24/20.
Elevators DONE
Tailcone DONE
Wing kit arrived on 7/30/20.
Began wing kit on 8/4/20.
Donated: 2021
