Old 09-14-2021, 05:05 PM
VanzAir-DragonBlaze VanzAir-DragonBlaze is offline
Default New RV-8/8A Builder
Well I just ordered my Empennage Kit. Step one of the build.
I saw RV Tools Kits but I think it is more cost effective to buy the tools as needed.
What are the needed tools for “Phase 1 Empennage?”
Also I saw the Tool Box and Light Sign. I do plane to complete those and my practice.
Old 09-14-2021, 05:28 PM
Drum Drum is offline
I don’t know….maybe a good set of tools if you don’t have any might cost 1-2% of your budget. But it might be frustrating to wait for tools to do a specific task. Also shipping is expensive. The right tool is everything. Believe it or not you’re probably going to make some tools yourself. Sometimes can get lucky on Craigslist or asking around at the airport for someone who’s not needing aviation tools anymore. Even the classifieds on VAF have sets every once and awhile. There are advertisers on VAF who have created quality tool kits specific to the planes we are building. You can go to a local A&P school and ask for the list of tools they are suggesting for their students. Also talk to EAA chapter and other builders about what they think. I’m pretty sure this is an area where you don’t want to cheap it out.
Drum G
RV-8
Avionics & Electrical
Old 09-14-2021, 06:07 PM
N804RV's Avatar
N804RV N804RV is offline
You definitely need to look at the "recommended" and "optional" tool lists in the preview plans! With current delivery times, I'm betting you've got plenty of time now to plan out your tool purchases.
One recommendation I would make would be to buy a nice new "ultra-quiet" dual-piston air compressor. I've seen the 20gal/2hp model for around $550 online. Come over to my house and listen to the obnoxious 20+ year old Craftsman compressor I have, and you'll see why.
Ken W.
Mount Vernon, WA
2021 VAF Supporter
Old 09-15-2021, 10:26 AM
THanks, that was one thing I was looking at. What size air compressor do I need?
I don’t want to cheap out on tools just buying closer to when needed. I dint have a garage I live in the city in a high rise so I have to rent a hangar (my brother and I took half my mom garage for our motorcycles maintenance and projects)
Im excited but want to learn from others experience as much as possible.
I started seeing different mods poeople suggest like extended tanks or electric trim safety .
Old 09-15-2021, 11:08 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Here's some advice - build the aircraft as close to the plans as possible. Every change will cost you a lot more time than you might think. I got this advice before I started building, didn't listen for a while, and then came back to understand the wisdom of it, which allowed me to finish and fly.
If you want to build a masterpiece with every bell and whistle, and are happy to take many years to do it, no problem - lots of people do this, and have built some amazing aircraft. If you want to fly, stick to the plans as much as possible.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 09-15-2021, 12:55 PM
N804RV's Avatar
THanks, that was one thing I was looking at. What size air compressor do I need?...
I wouldn't get any smaller than a 20gal tank, and any less than 5.7cfm.
Dewalt has one thats 5.7cfm at 90psi and a 30gal tank for less than $900. The noise level is 78db, which isn't too bad (I think).
But, that's just my opinion. I'm sure there are others.
Ken W.
Mount Vernon, WA
2021 VAF Supporter
Old 09-15-2021, 09:06 PM
claycookiemonster's Avatar
claycookiemonster claycookiemonster is offline
As to tool buying; I think it will become incredibly frustrating to continually come up upon needing a tool, and only order it then. All the tool companies know RV's and their recommended "tool kits" are at least a good start. If you have a builder who can comb through the list and advise on what you will NEED and what you'll only WANT, you're off to the races.
Two grand for tools may be jaw dropping now, but wait until you actually contemplate engines...
Clay "Cookiemonster" Cook
USAF: T-38, F-111F
American Airlines: 727, MD80, 757, 767, 737
RV8 #81751 project sold
RV8 #81651 project acquired
https://theonceandfutureflyer.wordpress.com/
Donations up to date thru December 2015
"...serenity...courage...and wisdom..."
Old 09-17-2021, 06:03 AM
N82VM N82VM is offline
Default Many suppliers
Several companies sell a complete tool kit. If there’s anything you don’t use or DO use it can be easily sold here on the forums at a small discount from what you paid. Always someone looking for a deal. Just consider the delta between what you paid and what you sell for later as a rental fee. If you spent $2k I doubt you’d have any problems asking $1500 for the lot. It would be gone within the day. Buy the tools sell them later when you’re done.
Slow builds need tools that QB’s don’t. Example I found other builders suggested a 12” rivet set for the main wing ribs to the spar. You need that length to get the rivet gun out of the way. Don’t see that tool on the list. Needless to say I was waiting on it after I figured out I needed it.
Ask around about the tools not on the list and buy them in anticipation.
PA-22-135
RV-8 Project
2021 Dues Paid
2017-2020 Dues Paid
Old 09-17-2021, 07:38 AM
Allan Stern Allan Stern is offline
Smile Tools You might need
Obviously besides a compressor you will need:
Rivet gun
A couple of tungsten bucking bars (others work but tungsten are super)
A good rivet squeezer
A set of good dimple dies
A C frame dimpler
A good air drill
A million #30 & #40 drill bits
There is a lot of other general tools you will need, screw drivers, punches, edge scrapper and deburring tools etc. Go to Oshkosh a great place to buy tools and stuff you never knew you needed.
Finally get to know other builders if any at your airport. They might have some of the exotic specialty tools on hand. Like hole saws or maybe a panel hole punch.
And if your build might have a specialty tool like the 14s get them a they make the build easier.
Flightline specialties has some nice readymade brake and fuel lines that save you time and frustration.
