Old Yesterday, 09:20 AM
FinnFlyer FinnFlyer is offline
Default Low-cost high-temp GoPro knockoff?
Looking for ideas for a low-cost action video camera that will tolerate engine-bay temperatures that can also be mounted under the wing for checking gear shimmy.
Any ideas or recommendations?
Also, any ideas on how to generate smoke that will show airflow inside engine bay?
Finn
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old Yesterday, 01:02 PM
Alchemist Alchemist is offline
I use older go pro 4 sessions, I picked up 2 for $80
https://www.youtube.com/watch?v=nyI1XIBCjOE
Justin Richardson
Vans RV-6A N457DH
Old Yesterday, 01:25 PM
krwalsh krwalsh is offline
Default Old GoPros
Your best bet is an older GoPro. We use them at work in, uh, "challenging" environments. We'd had them completely melted with the housings and everything turned to goo and we can almost always pull the SD cards and get the footage.
If you look just to right of center of this photo, level with the light on the wall, you'll see a GoPro. That one has been there a while and is working just fine. The ones on tripods that we put much closer end up being sacrificial:
https://www.johnkrausphotos.com/Gall...21/i-fxB7GHJ/A
Engine bay temperatures are nothing compared to what we subject them to.
Kevin R. Walsh
Cozy Mk-IV
Old Yesterday, 04:19 PM
Is that the engine to be specified for the RV-15?
Dave
