After spending months and months of (re-)searching, re-checking, even re-doing all grounding, dismantle and re-install generators, ordering and installing new ignition cables and better spark plug wires, even exchanging ignition coils for new ones and upgrading to newer ECUs, and spending a couple of thousand dollars on that and a technician I hired, we finally found out what causes the terrible ignition noise we had on the radio: the terminals of the spark plug wires on one ignition coil (I have dual EFII electronic ignition) were not tight enough and keep coming (too) loose. We keep crimping the terminals, but after a while they come a bit loose again.
The engine runs beautifully, but at some point you will hear the crackle in the radio again (up to a point you really are not enjoying the flight anymore, because of the tremendous ticking noise).
Simple (hopefully) question therefore is: does anyone know of better terminals I can install or some other solution for this problem?
We are 100% certain the problem of the noise is the connectors that go to the ignition coil. When we crimp them the noise is 100% gone (for some time). The cables we use are (as far as we know) one of the best out there: Taylor Wire# 60651 (HF carbon core wires). Before I used the Taylor Spiro Pro, which probably were just as good, but that was before we finally discovered the noise was caused by the connectors.
Any help in finding the best connectors (or other solution for them coming a tiny bit too loose) is really appreciated - it is the last thing that is keeping my RV from being totally perfect!
