Old 11-19-2015, 09:00 PM
BillL BillL is offline
Originally Posted by BSwayze View Post
Larry, I'm embarrassed about what I did but I'm happy to post my goof-up if it may save someone else from repeating my mistake. Basically I jumped in and moved too fast without thinking. I measured carefully to see how much room I had on the underside of the glare shield between the canopy frame tubing and the forward canopy brace that's riveted to the frame. Where else are you going to put fans on a tip-up? It appeared that standard 80mm fans, commonly used in desktop computers, would fit perfectly under there. And they do! So I bought a pair of nice fans, cut the holes in the glare shield, drilled for the corner bolts, and installed the fans. I was so pleased at how they looked and seemed to fit perfectly. I put the canopy back on the plane and I was thrilled.
So fast forward a bit... my panel wasn't in the plane at the time. Now you know the instrument panel has a stiffener angle that's riveted across the top over the curve, to stiffen and strengthen the panel blank. When the canopy is closed, the top of the panel and that stiffener fit right behind the tubing on the canopy frame. There must be room under the glare shield for that, and when I tried to lower my canopy after putting the panel in, it wouldn't close. The fans were hitting it! There MUST be a gap under there for everything to fit in place when you lower the canopy.
It was a shock, and a huge disappointment, as you can imagine. I was literally sick to my stomach. Here is the canopy that I spent so much time on, so much attention, months of work and effort on every detail. And in a brief moment I cut holes that are too big and installed fans that won't fit! How am I going to fix that? There's no going back. Now I'm stuck and didn't know what to do. It took me a while to figure out a workable solution that still looks good. Otherwise, it's a rebuild of the whole canopy, or patch it up and be embarrassed about it forever. But I finally figured out a way to turn this lemon into lemonade. You can see the smaller 52mm fans that I settled on here. They turned out to be the perfect size. You can find endless fans and sizes by shopping online. Just google "computer fans". I ended up mounting them on square plates that fill the original holes that I cut, using the corner holes that I had already drilled. Looking closely above, you can see them. In the end, though, they're hardly noticeable and I'm okay with this. In fact, if I ever have to change them out, it may be even easier this way.
So that's the story. At the end of the day, I know I'm going to enjoy having these fans here in the foggy-windows humid Northwest. Just be careful and avoid my mistake.
Almost happened to me too. Had the 4" fans and went to mount them, and suddenly it hit me, or they hit the panel. They just would not fit! We all think the same way and that canopy makes one have to think 10 steps ahead. Very complicated.
Bill
RV-7
Old 04-15-2017, 04:54 PM
PipeDreamer PipeDreamer is offline
Default DRDT vs C-Frame
Hello Bruce, a newbie builder here and looking for a starter tool set, on your weblog you have elaborated on DRDT vs C-Frame (under-dimpling issue). A lot of people swear by DRDT, I just wonder if you have came to a conclusion of some sort?
Old 11-22-2017, 06:37 AM
BSwayze's Avatar
BSwayze BSwayze is offline
Actually, I have. At first, I adjusted the DRDT with not enough pressure to form a good clean dimple. It was under-dimpling. Once I adjusted the ram by extending it, the dimple dies contact each other when you pull the handle down much sooner. About half to 2/3rds of the way down, with no aluminum part between the dies. It literally bends the arm of the DRDT a bit when the arm is fully pulled down. Once adjusted like that, I pulled the handle twice for each and every dimple. Once to form the dimple, twice to really slam it and make it crisp and flat. Doing it this way, you get good dimples that are almost as good as a c-frame.
I say "almost" because once I bought my c-frame and hammered each dimple twice (hard), those dimples just can't be beat. It takes a sharp eye and a close look to see the difference. It's a small difference, but it's there. In my experience, the c-frame produces slightly better dimples that have crisp edges, and the metal around it is totally flat. So is the difference compelling enough to consider a c-frame? That's up to the builder. Honestly, after riveting and paint, I don't think you could tell the difference which method was used, if it is all done correctly. But it is there and worth mentioning, to answer your question.
I would also say, a lot depends on getting good quality dimple dies. This is one place to get the best. Don't scrimp when it comes to these. I bought the spring-back dies from Cleveland Tools. There are probably other good ones out there, that's just what I bought. And I have no regrets.
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 11-24-2017, 10:41 PM
kentlik's Avatar
kentlik kentlik is offline
I have a set from The Yard Store and they form excellent dimples. I use the strike method in a tabletop deal and they come out bang on.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 11-25-2021, 08:18 AM
Draker's Avatar
Draker Draker is offline
Bruce, just a heads up, it looks like your excellent build log website is offline. Just thought you might want to know. Congratulations on your build and thank you very much for documenting your RV-7A journey in such great detail! It was a great resource for this builder.
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 12/31/2020
RV-7A (N12VD): Finishing final tasks for engine-start and airworthiness!
Old 11-25-2021, 11:29 AM
PBell PBell is offline
Default Yeah I miss it!
I always kept an open tab in my browser for quick reference, sorry to see it go.
PBell - 92293
N393RV reserved
2021 donation made
http://myrv-9abuild.com
Old 11-25-2021, 12:23 PM
mfleming's Avatar
mfleming mfleming is online now
Hope he's OK. He dropped off VAF just after COVID started....
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2021 and so should you
Old 11-25-2021, 12:32 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Default I think so...
Last flight was November 20th, 2021.
Brian Decker
RV-7 (Flying)
