SeanB
Hey everyone,
It's almost my turn to cut the plexi for my tip up canopy. I've studied many posts and builder sites in preparation. I still have a couple more questions before I start trimming:
Thanks for the help!!!
- Should I cut all the way thru the thickness of the material and make cuts in one pass or score the line with a light pass then cut thru?
- I made the typical table top with 2 X 4 rails to retain the shape of the canopy while in work. Should there be light pressure squeezing the sides of the canopy inward, or just retain its natural shape?
- In between trim cuts, what is the finest grit of sandpaper I should use?
