VAF on Twitter:
@VansAirForceNet
  #11
Old 09-24-2022, 03:47 PM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Is it worth 300 dollars (cost for IO 540). Thanks…….
Hey togaflyer, sincerely hope this thread’s gonna be more fruitful than it is right now… just so I can finish this popcorn stash I‘m now sitting on
Re your query, I think not. Most of those miracle additives, starting last century for horses and Model T Ford were, well, wishful thinking.
Abide to the engine‘s manufacturer recommendations, +/-. Once you‘ve flown with exactly the as recommended fuel, probably100LL for you, with no anything additive, for say 1K+ hours, please report here, with your findings
Engine manufacturers are riding on a two sided edged sword: longevity and profitability… so they are basically not to be referenced at.
Unforttunately most RVers here fly too little to have any conclusive experience…
PS not in any relationship to the thread, others just skip, thanks
Hey you red nosed Eric & Mickey, is that the same airplane, or not? Santa Claus is still a few weeks away, not?
- ain't the Destination, but the Journey -
www.aerofun.ch
YLL On Tour... the blook:
https://vansairforce.net/community/s...d.php?t=210564
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 09-24-2022, 07:31 PM
togaflyer togaflyer is offline
So for 99.99 dollars, if you act today, you will see an increase of your speed up to 25 knots, cut your fuel burn in half, never need to overhaul your engine, your spouse will never argue with you, your children will never say I know that to you, the sky will always be blue when your flying, but act know because this is a very very very limited offer………
Rich Gurr
RV 10 924RL
9A0 & FD51
Old 09-24-2022, 08:04 PM
wirejock's Avatar
wirejock wirejock is offline
Default Water carburetor
I'm saving my money for one of those carburetors that makes the engine run on water!
Sorry, I'm that old.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 09-24-2022, 08:41 PM
RussellT RussellT is offline
Default Worked for me
I put some Teflon type stuff in an old Ducati (dry clutch) with a gearbox full of missed gears and false neutrals, generally unpleasant to ride. Difference was dramatic and it now changes gears like a Honda and I can now get the proper neutral without switching it off... I don't ride it often though so it should take a while to clock up 200 miles.
Russell
RV 3B. Very slow build. Now onto final assembly...
Old 09-25-2022, 09:23 AM
9GT's Avatar
9GT 9GT is offline
Snake oil.
David C.
Howell, MI
RV-10: #41686 Under Construction/Sold 2021
"Donor Exempt" but donated through Dec. 2021
Old 09-25-2022, 10:36 AM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Default Harmful
I know first hand that using Teflon additives will lead to early engine failure. 98 f150, tried the Teflon additive. Engine failed around 130,000 miles iirc. Rebuilder noted all small oil galleys clogged with Teflon.
Wade Lively
-8, Flying!
N100WL
formerly IO-360A3B6D, Dual SDS CPI now, WW 200RV
Old 09-25-2022, 12:23 PM
Roadjunkie1's Avatar
Roadjunkie1 Roadjunkie1 is offline
Default Really?
Ooooo...! I remember those!!
I put one of those magnets on the fuel line that realigns the fuel molecules so they flow parallel and am now only using 3.5gph.....
Michael
RV-4 2860 SuzieQ
1946 C-90-8 J-3 Cub
The adventure begins when things stop going as planned - Glen Heggstad
Exempt but still a happy Subscriber! 2022-2023
Old 09-25-2022, 01:16 PM
airguy's Avatar
airguy airguy is offline
I'm thinking of trying the hydrogen generator thing...
Garden City, TX VAF 2022 dues paid
N16GN flying 1,200 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Repeat Offender - 10 empennage in process.
Old 09-25-2022, 01:21 PM
RV8iator's Avatar
RV8iator RV8iator is offline
Default Mineís coming soon
Iíve preordered the aviatorís flux capacitor. With only half down, delivery was promised soon..
Jerry "Widget" Morris
RV 8, N8JL, 3,200+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2007 - 2022
I just wish I could afford to live the way I do
Old 09-25-2022, 01:51 PM
Stewbronco Stewbronco is offline
Default AVBLEND
Been using AVBLEND …..about 40 years ( long before it was called AVBLEND) …..I intend to continue…but I steer clear of all other oil additives EXCEPT CAMGUARD …..I add them both every oil change
