  #11
Old 03-30-2021, 07:15 PM
JDA_BTR JDA_BTR is offline
On the 14 it is really easy to mount a tabs plate on the aft side of the right firewall with a through bolt to the other side where the normal ground bolt and connection is made. The wire runs to that tabs location are easy enough.
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 03-30-2021, 07:58 PM
johnbright's Avatar
johnbright johnbright is offline
Default load on IP ground bus
In my case I followed a combination of Bob Nuckolls and manufacturer's recommendations for grounds and ended up with 16 A max on the subpanel tabs.
Not implemented yet, my schematic shows two 14 awg wires from tabs on the IP tab block to tabs on the firewall aft tab block. Bolts could be used as long as they are two separate bolts for redundancy. If one of the 14 awg connections fails it will be a benign failure detected by physical inspection at next annual. The IP tabs are also bolted/grounded to the subpanel so it's triple redundant.
Items locally grounded: pitot heat, landing lights, interior/map/glareshield lights, nav/strobe mounting brackets, flap motor, seat heaters, 12V outlets and USB chargers, defrost fans, stick switches.
Grounded to the subpanel with its own bolt: nav/strobe ground return (current-carrying) shields.
John Bright, RV-6A, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
Z101 as a template, links
Old 03-31-2021, 12:18 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Been there, done that ... until my builder supporter pointed his finger onto.
I measured then the resistance, increased the square size of the wire and made an additional one, so that the resistance was greatly reduced.
Don't remember all the measurements, but he was right. Also, 10 times easier to do now, than later when you may think that there is a problem ;-)
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 03-31-2021, 03:31 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default # of tabs
Just a suggestion - don't underestimate the number of ground tabs you will need. I recently had to add some, much to my surprise. "The best-laid plans of mice and men ..."
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 03-31-2021, 08:57 AM
PilotjohnS PilotjohnS is offline
Default yup
Truer words were never spoken.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 85% in work
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
www.pilotjohnsrv9.blogspot.com
Old 03-31-2021, 01:25 PM
mfleming's Avatar
mfleming mfleming is offline
Very true
24 tab mounted on the firewall cold side for all the grounds from boxes between the sub panel and firewall, 20 tabs on the co-pilot side of the sub panel for avionics and 20 more tabs on the pilot side for switch grounds
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring completed
Avionics harness build in progress
Donated for 2021 and so should you
