Old 04-14-2021, 09:32 PM
Lt Dan Lt Dan is offline
... does a P-mag offer a way to fixate the wires against vibration? ...
Yes. They tell you to make sure you use adel clamps on the P Mag.
Click image for larger version
Name:	Screen Shot 2021-04-14 at 9.30.43 PM.png
‘08 RV-4
‘09 RV-8
Old 04-14-2021, 09:43 PM
A little off the original topic here, but very useful and applicable information. While we're on the subject... I'm not a builder. One day I will be, but in the meantime, I plan to learn everything I possibly can by working on my bird. On that note, what is the approved solution for aviation "heat shrink" and the like, once you've crimped/soldered/butted your wires together? I ask specifically because I now have exposed connections that I uncovered while tracing my tach problem. They were covered in some kind of balled up rubbery electrical tape that might have done the trick but was at the very least unsightly. I'm wondering how people get those beautiful finishing touches like in Jim's last photo. See attached picture to get an idea of what I'm working with.
Name:	Tach Wires - 1.jpeg
‘08 RV-4
‘09 RV-8
Old 04-14-2021, 11:27 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Originally Posted by Lt Dan View Post
...what is the approved solution for aviation "heat shrink" and the like, once you've crimped/soldered/butted your wires together? ...
Two solutions: 1) slide some heat shrink on the finished connection like you have in the photo; 2) put the heat shrink on before finishing the connection and make the connection in a straight line.
If you want to learn a lot about wiring best practices, spend some time on this site: http://www.aeroelectric.com - there are a lot of hints and tips there.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 04-15-2021, 07:23 AM
DanH's Avatar
DanH DanH is offline
A little off the original topic here, but very useful and applicable information. While we're on the subject... I'm not a builder. One day I will be,... I'm wondering how people get those beautiful finishing touches like in Jim's last photo. See attached picture to get an idea of what I'm working with.
Those are awful splices. You can slide some shrink tubing over them, but note how pulling the wire just splits the tube and stresses the wire across a 90 degree bend.
Want to be a builder? Time to start your tool investment. The standard butt splice is an AMP PIDG. You'll invest in the correct ratcheting crimp tool, which guarantees the correct degree of crimp. A PIDG does not require shrink tubing. Here is one popular source: https://www.steinair.com/product-cat...erminals-tape/
Shrink tubing comes in many varieties. The good stuff is 3-to-1 or 4-to-1 shrink, lined with heat melt adhesive, as it significantly improves fatigue performance and seals it against the elements. There is also clear, no adhesive, which makes for nice labels, and lots of specialty types:
https://www.delcity.net/store/Shrink-Tube-&-Tape/
If the shrink covered connection is preferred, use a bare, brazed barrel terminal:
https://www.delcity.net/store/Non!In...01870.h_801871
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-15-2021, 08:25 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
If you absolutely have to solder wires, I recommend you use one of these Solder Sleeves, in the correct size. Used correctly not only do they make a good electrical connection, they provide mechanical support.
You can also splice them together with one of these Wire Overlap Connector. Make sure you get the correct hex key for it. They are a bit pricey but well worth the extra cost.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2021 Donation made
www.PuertoRicoFlyer.com
Old 04-16-2021, 02:15 AM
jakej jakej is offline
Ok I got it, some people just want to make it appear difficult -
1. Why not just solder the wire - with care & the correct technique the just very end of the wires can be soldered without solder wicking much at all.
2. Each P-Mag has a p-clip fitted & my method is to cable tie the wire loom (usually 3-4 wires) to it. That makes it easier to completely remove the mag for annual (100hr) inspections- much easier than trying to remove the cap screw in situation.
3. IMO securing the wires to the p clip close as possible to the connector will give all the support needed & therefore mitigate the risk of wire breakage. It’s not rocket science
It appears in an earlier post that an OP wire may have been loose because the wire was not in place properly to start with - the slotted screws need to be undone first before inserting the wires ( I’ve made that mistake, once) , do the screws up & then do the standard ‘pull test’. 650+ hrs & many P-Mag installs later without issues since.
Old 04-17-2021, 12:12 AM
This site is a gold mine! Thanks for sharing!
Perfect. Exactly what I needed to know. Thank you!
Thanks for the info!
‘08 RV-4
‘09 RV-8
Old 04-17-2021, 12:13 AM
Do you have a picture you could possibly share? It sounds interesting but I'm having trouble visualizing your setup.
‘08 RV-4
‘09 RV-8
Old 04-17-2021, 07:12 AM
Walt's Avatar
Walt Walt is offline
Hate to disagree but Solder sleeves are made for terminating the shield on shielded wire not joining wires.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1900+ hrs, New Titan IO-370, Bendix Mags
Old 04-17-2021, 09:11 AM
vlittle's Avatar
vlittle vlittle is offline
To be more specific, crimp terminals should meet MS25036 specifications. Both Amp (TE) PIDG and Molex AVIKRIMP brands meet this specification. When I built my Rocket, the inspector actually asked the specific brands of my terminals.
V e r n. ====
RV-9A complete
Harmon Rocket complete
Member of OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
