  #41
Old 03-09-2021, 06:01 AM
carlrai's Avatar
carlrai carlrai is offline
Default Had similar experience
[quote=Noah;1508603]Thanks Bill. Some good thoughts there.
I removed my diode pack and flipped it over. Here's what it looked like. Thoughts? The stator field wires all seemed intact, none broken there.
Similar experience with the diode stack on my PP. Replaced with this - Restored and working fine.
Replacement Diode Stack
Carl Raichle
Lutz, FL
RV-9A N194CR
RV-14A Under construction
Based at KZPH
AA4SR
Old 03-09-2021, 06:44 AM
DanH's Avatar
DanH DanH is offline
Seems like the B-lead post has been subject to vibration. Too much hanging wire?
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-09-2021, 09:44 AM
Noah's Avatar
Noah Noah is offline
Yes, it sure does look like it from the cracks in the rectifier, doesn't it? Curious, since my B-Lead was secured to the cover with a large zip tie about 2-3 inches from the B-Terminal so any vibration would be limited to a direction along the axis of the B-Lead.
Originally Posted by carlrai View Post
Similar experience with the diode stack on my PP. Replaced with this - Restored and working fine. Replacement Diode Stack
Thanks!
My engine monitor records all parameters once per second but never recorded a voltage spike, yet my field breaker tripped. If there are voltage spikes, are they likely to be incredibly short duration events, so that the engine monitor is unlikely to catch them even at its fastest recording rate of 1/s? Or are there other VR failure modes (unrelated to overvoltage) that would cause the field breaker to trip? Would a cracked/intermittent rectifier lead to overvoltage & crowbar shutdown via field breaker trip?
Is there any documentation available regarding bench test procedures for these alternators? I couldn't find one on PP's website. I brought this to an auto parts store to test but they couldn't do it since their test setup requires a vehicle make & model, and the regulator is modified by PP so the electrical connections are altered. Maybe going to a real alternator shop instead of a parts store is the key?
My tension arm bracket is also cracked so I'm looking for one of those if anyone has one available...
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 03-09-2021, 12:14 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Default Cracks...
Maybe not the "B" lead flopping around but an out of balance pulley, rotor or both - you can spin it up to a few thousand RPM and feel the vibration if that's the case.
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 03-09-2021, 01:42 PM
BillL BillL is online now
Where did you find a test procedure for this alternator? I could not find one.
Can you post a picture of the bearing on the slip ring end of the rotor? This could be critical to your ability to complete the rebuild. This end bearing is a whole new subject in itself.
I tested a PP with a fried diode and the voltage was low and drawing high amps from the field to try and reach output voltage.
Look at the circuit diagram on page 6. Note that the rotor has one leg attached to the B lead (+12v). The PP has that connection as external i.e field wire. Now, Locate F and note that you can ground it to give the field full raw 12DCV power. That would drive up the voltage and let you know that the alternator can make power. The regulator controls the output voltage vis the ground side.
A moot point on the diode bridge now, as you really need one.
Here is the test procedure. Click and save as . . .
Click image for larger version
Name:	Toyota Alternator testing.pdf
Bill
RV-7
Lord Kelvin:
I often say that when you can measure what you are speaking about,
is of a meager and unsatisfactory kind.
Old 03-10-2021, 08:49 PM
Noah's Avatar
Thanks for the test procedure and diagnostic info Bill, very helpful! I also found this video for troubleshooting and bench testing one of these alternators:
https://youtu.be/at_R7sENE0s
Incidentally testing my cracked rectifier showed that all diodes were good but since my problem is intermittent that shouldn't be too surprising that it seems fine. I'm hoping that replacing it will correct my issue.
I have not opened up the case to get a look at the bearings since mine feel fine but I'll snap a photo if I do.
Highest Regards,
Noah F, RV-7A
Old 03-11-2021, 04:35 PM
jdeas's Avatar
jdeas jdeas is offline
Default 2nd
Originally Posted by lr172 View Post
It seems the common failure for these alternators is broken wires on the stator. May want to give a look inside before modifying the VR. Several posts on the subject.
Larry
Replaced a regulator board once when one of the three stator windings broke. Didn't fix it and didn't see the real problem until the 2nd wire broke as well killing all output
JD
RV-7 N314SY (KWHP)
IO-360-B1B
A&P
CANbus based trim/flaps and electrical
Old 03-21-2021, 07:27 PM
Noah's Avatar
New rectifier assembly seems to have fixed my popping field breaker issue. Test flight today and all is well.
Highest Regards,
Noah F, RV-7A
