VAF on Twitter:
@VansAirForceNet
  #51
Old 11-11-2022, 07:24 AM
vic syracuse vic syracuse is offline
Super Moderator
Default Check the bearing
We do find a few of these PMAGS with bearing play every year, so please do check them. EMAGAIR has been very quick at truning them around.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES/RW
Kitplanes "Unairworthy" "Diagnostics" monthly feature
EAA Sport Aviation "Checkpoints" monthly column
Author "Pre-Buy Guide for Amateur-Built Aircraft" & "Are your Nuts Tight?"
www.Baselegaviation.com
  #52
Old 11-12-2022, 03:41 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Vic
Not saying I would do that, but what would happen if you ran it to failure? I like to understand the edge cases.
Mickey Coggins
http://www.rv8.ch/help-people-in-ukraine/
  #53
Old 11-12-2022, 06:21 AM
Walt's Avatar
Walt Walt is offline
Probably the same thing that happens when a neglected impulse coupler fails, parts fall into the accessory case and cause bad things.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
  #54
Old 11-12-2022, 08:06 AM
Dad's RV-10 Dad's RV-10 is online now
FWIW, I emailed P-Mag to ask some questions about the bearings in the 6 cylinder P-mags vs. the 4 cylinder units. I have 6 cylinder P-Mags but the engine hasn't been run yet (other than on the test stand).
Regarding the bearings in the 4 cylinder P-Mags, Brad replied that the 4 cylinder units have one large bearing and one smaller bearing in the stack whereas the 6 cylinder units have two of the larger bearings on the main drive.
The small bearing in the 4 cylinder stack has recently been enlarged.
I'm not sure if that means that older 4 cylinder units sent to P-Mag for service will get the enlarged smaller bearing or if it means that new production units come with the enlarged smaller bearing? But I thought it was worth noting here, since there was discussion of bearing wear and inspection.
  #55
Old 11-12-2022, 11:21 AM
rv8ch's Avatar
Thanks Walt. Doesn't sound like something we want to happen.
Mickey Coggins
  #56
Old 11-12-2022, 11:35 AM
Toobuilder's Avatar
Magnet air gap is also something to consider. Aside from the trash generated from a bearing coming apart in your accessory case (accessory gear timing is kind of important), magnet misalignment caused by an out of true shaft is likely to cause a shutdown, or worse, a mistiming event.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
1940 Taylorcraft BL-65
1984 L39C - SOLD
RV-8 - SDS CPI - SOLD
  #57
Old 11-12-2022, 03:32 PM
Northernliving Northernliving is offline
Originally Posted by robert@jonesrv10.net View Post
I made some cooling shrouds for the front of the PMags out of Carbon Fiber. They wrap half way around the PMag and have a 1" blast tube hooked to them. They were easy to make and make the blast tubes more effective. I used the rounded end of a 2X6 for a mold and tapered it just a little to make the shroud easier to get off the mold.
Hi Robert,
Would value seeing a picture of what you made if you don’t mind posting.
- Brian
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
New Superior IO-360-B1AC2 w/Hartzell Composite CS
RV8 - #83313 - Under Construction (sort of!)
  #58
Old 11-17-2022, 05:29 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Yes bearings were changed and retrofitable. I talked to Brad he said no need to change if play and rotation are good. A non mandatory change but small incremental changes, r
continuous design improvements. But the original design is fine and many PMags are in service with 1500 hrs or more, with no bearing issue. Just inspect you are good.
Yes bits in accessory case is bad. The PMag is not the issue but some aftermarket gears made for a time with less hardness. This is the same non impulse magneto gear used on your magneto. Two things: The load on gear is light and many of these softer gears have no issue. Second the issue was not wide spread, but there were a few cases of premature wear.
Another good reason to remove PMag yearly to inspect shaft play and rotation, as well as gear. You can assure you have the better or OEM Lycoming gear through markings or hardness test. A genuine non impulse Lyc gear is $450. A non certified gear is $225., which is equivalent to the Lyc gear.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2023 Donation Made!
  #59
Old 01-02-2023, 06:55 PM
robert@jonesrv10.net robert@jonesrv10.net is offline
Originally Posted by Northernliving View Post
Hi Robert,
- Brian
Send me your email and I will send you some. Mine is robert@jonesRV10.net
Robert Jones
Las Vegas, NV
RV10 N810K
  #60
Old 01-02-2023, 07:11 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Can you post a copy of the photos? There are more of us that would love to see your design.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2022 Donation made
www.PuertoRicoFlyer.com
Closed Thread
