Go Back   VAF Forums > Model Specific > RV-14
  #21
Old 01-02-2021, 02:30 AM
FlyinTiger FlyinTiger is offline
Smile A modern engine
I'm watching with interest. Looking for these modern engines to run a few thousand hours reliably, technological advances are exciting.
Next, examples of electrically governed props being used with these engines and learning about maintenance cycles/reliability of these systems in the experimental world.
Maybe UL will build FWF kits for RVs since they are one of, if not the most popular experimental aircraft built.
AL
Launching from SC45
Old 01-03-2021, 02:41 PM
swisseagle's Avatar
swisseagle swisseagle is offline
The RV-8 mentioned in one answer, flying with an UL engine:
- Needed an additional engine mount, the one from the engine supplier was not strong enough.
- It flew
- Had an unexpected engine shutdown, luckily on taxiway
- Somehow engine is running very rich
Now it sits in the hangar corner ...
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 01-24-2021, 02:11 AM
Mike Houston Mike Houston is online now
Ray Lawrence, the UL importer, is a friend of mine. His 220 HP UL turbo has so far, maintained 36” up to 13,000’ ! He now has intercoolers installed and with his recently acquired oxygen, plans to go near 18,000’ for further tests..stay tuned...😊
Regards,
What type of plane is he running the engine on?
Old 01-24-2021, 03:19 AM
Peter Costick Peter Costick is offline
FWIW
I know absolutely nothing about UL Power and so I don't comment on them.
But I will echo earlier comments about increasing the complexity of the build. I would estimate any change to the kit design adds many many times to the complexity, often in ways you would never expect.
My own experience with what was sold as a bolt on and go engine based on the Subaru STi from what was then a Florida based company ended in failure, and a loss of $10,000's. It nearly killed the whole project, and certainly put it back many years. I count myself lucky, a friend who also bought the same package got it flying in his RV8, after much work, and expense, but ended up crashing into a forrest when the engine suffered multiple internal failures in flight.
Now I am happily flying behind an Aerosport Lycoming. And the guy who crashed his RV8 walked away mostly uninjured.
Caveat emptor
Peter Costick
Melbourne Australia
RV7A Flying, VH-SVN
2020 Donation Made
Old 01-24-2021, 03:57 AM
pierre smith's Avatar
Default RV-4
Mornin’ guys.Ray has the engine in his RV-4, turned out to be a Rocket in performance! I was just there a couple of days ago and saw the longer motor mounts and cowls already developed for the RV-8, 7 ,9 and -12.
I’m putting one in my RV-12 shortly and the other -12 has incredible performance with its 130 HP UL engine.
Regards,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 01-25-2021, 02:01 AM
Regards,
Very interesting, there new Turbo 520 would be suitable for the RV14 and maybe the RV 10. 220HP @ 8000 ft must be up there with the IO-540. Do you know if they are looking into FWF for those planes, those are the ones I am interested in.
Old 01-25-2021, 03:12 AM
jakej jakej is offline
Originally Posted by Peter Costick View Post
FWIW
Caveat emptor
Wasn’t that his 4 engine ‘issue’ ? Sometimes a Lycosaurus is a better option.
