Go Back   VAF Forums > Main > Safety
  #11
Old 05-20-2019, 09:07 PM
AirHound AirHound is offline
Default CO Levels Experience
Anyone care to share RV12 detections/indications per flight phase.
Old 05-21-2019, 08:33 PM
Captain Avgas Captain Avgas is offline
Originally Posted by bkervaski View Post
Just about everyone at our field uses this one ...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Would you hear the alarm buzzer on this unit if you were wearing an active noise reduction headset. You may or may not see the alarm light depending on where it is mounted. Generally RV pilots don?t tend to have too much panel real estate ahead of them.
You’re only as good as your last landing
Bob Barrow
RV7A
Old 05-21-2019, 09:35 PM
rongawer rongawer is offline
The answer is yes. I have it mounted on the right side of the panel. It is not only loud, it has a flashing light and read out. Works fine. We discovered my buddy?s Cessna 150 had an exhaust leak.
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
Old 05-21-2019, 11:44 PM
bkc3921 bkc3921 is offline
Default Aithre
Would you happen to know if the Aithre will connect with ANY of the Advanced Flight System EFIS, or just the newer ones..? My AFS is a little older (3400 series, one standard screen and one synthetic vision screen)....just wondered if the older software supports this...thanks in advance.
Brian K. Morrow
DuBois,Il
N433BC RV-7A Flying
RV-12is EMP done, FUSE in progress!..Official Repeat Offender
"Maintain thy airspeed...Lest the earth arise and smite thee..."
Old 05-22-2019, 11:54 AM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Default Best to check
Brian - I do not know. Best to check with them. They did respond very quickly and were super helpful when I had questions.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 01-17-2021, 07:18 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default webinar on CO
I've got this one as well in my RV8. I tested to make sure it works with candles, car exhaust, and it trigged once that I can recall when I was waiting to line up with wind at my back. It seems to work well. Normally it shows 0, which is what I want. I power it on for the calibration step after moving the aircraft out of the hanger with the canopy open and of course engine off.
I just saw an EAA webinar (https://eaa.org/Videos/Webinars#) with faast credit about CO and it was scary - both the story the presenter told, and the fact that he says his CO detector "only" runs at a constant 20 now after repairing his exhaust system. If mine showed anything above zero during normal operations I'd be looking for leaks.
Perhaps I'm being a bit too persnickety, but CO has caused many pilots to have a very bad day.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-17-2021, 07:24 AM
Scott Hersha Scott Hersha is online now
Amazon site says no longer available, but I was over at Sporty’s last week and they have them in stock for $99.00
https://www.sportys.com/catalogsearc...=co%20detector
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2021
