Old 01-31-2021, 04:16 PM
Aquaman! Aquaman! is offline
Default Lycoming I/O360 idle RPM?
I have recently purchased a Dick Colliander built RV-8
It has been over 3 years since my RV-8 has flown and I recently swapped a slick mag with an Emag electronic ign, installed an EchoUAT ADS-B. Before I reinstall the nose bowl for test flight I'd like to reset the idle rpm. Any suggestions for minimum idle RPM?
Also,
I'm putting together a POH for my recently purchased RV-8. Does anyone know a good source for an operators manual and possibly a Pocket checklist (PCL) that fits in the glove box?
Old 01-31-2021, 04:22 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
https://vansairforce.net/poh.htm
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-31-2021, 04:29 PM
BillL BillL is offline
Also,
You should check out Kevin Hortons website. He is a test pilot and did an excellent job of his POH - - Not likely a pocket size though.
Bill
RV-7
Lord Kelvin:
I often say that when you can measure what you are speaking about,
is of a meager and unsatisfactory kind.
Old 01-31-2021, 04:46 PM
Thanks I'll look at it now.
Old 01-31-2021, 04:58 PM
scsmith scsmith is offline
My angle-valve IO-360 has idle set at about 600. With the very light WW prop, it is a little bit lopey, but OK.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 01-31-2021, 06:02 PM
Full Throttle Full Throttle is offline
A well tuned Superior IO-360 angle valve engine can idle below 250 RPM's.
I have one with a AFP-200 and two Aerosparks electronic ignitions that does just that. Smooth as silk. Timing is very important at that low RPM. Must be no more than 0 advance BTDC.
Old 01-31-2021, 06:42 PM
smithflys23 smithflys23 is offline
I didnt know it was possible to set the idle this low.
Is there any hesitation if you rapidly advance the throttle?
Old 01-31-2021, 07:04 PM
With an AFP-200 throttle body. I can advance the throttle normally. If I advance it too fast, it gets too lean to run and dies. Maybe with electronic fuel injection it could work.
Old 01-31-2021, 07:57 PM
TigerMan92 TigerMan92 is offline
Default Template POH
Here is a good resource for a custom / template for a POH.
https://alphazuluaerosports.com/products/
Gene
KOZW
RV-7A, XIO-360, MT CS 3Blade, Slider
Old 01-31-2021, 09:20 PM
nomocom's Avatar
nomocom nomocom is offline
Default Idle oil pressure
..idle below 250 RPM's.
Im curious. What do you see for oil pressure when the pump is turning that slow?
Stan
1990 RV-3 (now apart, upgrades in the works)
1959 C172 O-360
