Go Back   VAF Forums > Model Specific > RV-15
View Poll Results: Pull Rivets or Solid Rivets?
Pull Rivets 59 33.52%
Solid Rivets 117 66.48%
Voters: 176. You may not vote on this poll
  #21
Old 07-29-2021, 11:27 AM
RJK983 RJK983 is offline
I canít vote as Iím in the ďsensible mixĒ camp.
Driven flush heads where there is a clear benefit
Driven generally on internal sub assemblies that are built on the bench and are solo builder operations
Pulled where there is a clear benefit
With a lean towards pulled where possible on big skins to allow for single builder working.
But generally flush finished on the outside for all the painting, aesthetic and aerodynamic advantages.
Rich Kennedy
RV6A - 1/3 Share Flying
RV 14 Emp in progress.
Old 07-29-2021, 09:09 PM
Renfield Renfield is offline
Having been a structural engineer for over 35 years Iíd much prefer drivens, despite the extra work.
In my experience blinds donít hold up as well over the long term in joints with significant load transfer and theyíre more prone to corrosion than drivens.
That said itís entirely possible to design for blinds and use drivens in that small number of locations on the airframe that warrant it. Then you just have the cosmetics which everyone will have a different option on.
Thanks to Vanís for continuing to create new airplanes! Iím sure the 15 will be another excellent bird no matter which way they go.
RV-4 (project sold off eons ago)
RV-10 in planning stage
Aerospace Engineer 1986
Old 07-29-2021, 09:21 PM
rcarsey's Avatar
rcarsey rcarsey is offline
I think a smart mix of both.
I don't know what the performance penalty is for pulled rivets.. eg what the speed difference is between a rv-12 and one of the few rv-12s built with pounded rivets.
Rob Carsey, North Brunswick NJ
RV-12iS (N713) / Completed 12/2020
ASEL, Glider, AGI/IGI, LSRM-I, FCC GROL
Old 07-30-2021, 06:54 AM
Mel's Avatar
Mel Mel is offline
There should be no performance penalty for pulled rivets. The only performance penalty would be if round head rivets are used instead of flush. And even then, the speed penalty wouldn't be noticeable at the speeds we're talking.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-30-2021, 02:12 PM
bhassel's Avatar
bhassel bhassel is offline
Personally, I've driven and pulled. I think I prefer pulled for a number reasons most already mentioned in the posts.
Bob
Bob Hassel
NM
Subscription Paid for 2021
Home is where the hanger is...
Old 07-31-2021, 08:20 AM
cgeyman's Avatar
cgeyman cgeyman is offline
Default Mix
Flush on wings; pulled on fuselage and hard to reach areas😊
Old 07-31-2021, 10:19 AM
David Z David Z is offline
I think a lot of planes end up in a similar style to that. Driven rivets in the easy and medium spots. Pulled rivets in the hard - impossible spots. Frequently threads appear asking "how do I buck these...". Usually an answer appears with either CherryMax rivets or one MK-319-BS in a tricky spot in a line of solid rivets (small rib noses, etc.). CherryMax are significantly more expensive than normal pulled rivets used by Van's, so there is that to consider I suppose.
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage at the "porcupine stage"
83126
Dash 8 day job is financing the RV8
Donation till September 2022
Old 07-31-2021, 10:34 AM
scsmith scsmith is offline
There is a very important point here that no one else has mentioned. A back country airplane is exposed to a harsher environment, more often. Pulled rivets are an open door to environmental attack. Moisture and crud (which holds the moisture in longer) are inevitably going to get into pulled rivets. Bad juju.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 08-01-2021, 09:53 PM
FlyNSoCal FlyNSoCal is offline
Default Pull Rivet for Solo Build
I'm fine with a mix of pull and solid, providing the solid rivets can be installed without the need for a 2nd person to buck the rivets. I think it would save lots of hassle if the rivets can be installed solo. I've heard the stories about how fun it is to enlist assistance from others, but some of us don't have an abundance of skilled, or even unskilled help.
Old 08-02-2021, 03:46 AM
ksauce ksauce is offline
Default Why not both?
I think this is a false choice. The SPA Panther's design allows the builder to choose their style of rivet. In fact, not only can you choose between solid or pulled rivets, you can also choose between flush or protruding. Some folks elect to mix and match.
Kevin
