Old 11-02-2014, 02:16 PM
f1rocket's Avatar
f1rocket f1rocket is offline
Yep, I kind of opened myself up for that one. What I should have articulated better is more of a local condition specific for our field. If you get too slow in final, the swirling winds off the ridge line can cause your airspeed to drop very quickly so we tend to not get too slow on final to account for this. Once over the ridge, you can slip it but that builds up speed pretty quickly and the ridge is close to the end of the runway too.
I'm really not a bad pilot. Really.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 11-02-2014, 04:53 PM
sandpiper sandpiper is offline
Isn't the point of a slip to increase decent without gaining airspeed?
John Horn (donated for 2020)
Independence, OR
LSRM-A, CFII
Rotax Service, Maintenance, and Heavy Maintenance Trained
Building an RV-12, N7878H reserved
Flying a Flight Design CTSW
Old 08-24-2021, 07:18 PM
edmondthx1138 edmondthx1138 is offline
Default RV-12iS Idle RPM Fluctuation
I recently noticed my RV-12iS (about 40 hrs TT) exhibit RPM fluctuations with engine at idle (app. 2,000 RPM)
This happens during descent with throttle at idle or taxiing back to the hangar after the flight.
The RPMs will fluctuate in a consistent and regular cycle from 1,900 to 2,100. It will climb to 2,100, drop to 1,900 and then continually repeat.
Is this normal?
Old 08-25-2021, 05:44 AM
Amadeus Amadeus is offline
Is this normal?
Not normal. That sounds something like an intake manifold leak.
Purchased N112DR E-LSA flying with 28.2 hours - Thank you David (CraftingN112DR) for putting your skills, knowledge and attention to detail in this RV-12iS!
Dropped at paint shop this morning (July 15, 2021)
Picked up from paint shop (August 14, 2021)
Donated
Old 08-25-2021, 07:02 AM
bobg56 bobg56 is offline
Flight idle will be higher than ground idle due to having forward speed so if your ground idle lowest rpm is 1650 your going to see 1900-2000, if not a little more flying the pattern with throttle at idle. I like to pull throttle when abeam the numbers and see if I can land without touching the throttle, good practice for engine out.
