Last weekend was a good one for RV building. Snowed all day here in Kalamazoo and after having about a week of 50-60 degree weather, it looked like the middle of winter again. So turned up the oil burner in the shop and set to some building, with help from a couple of guys who were surely escaping honey-do's back home.
The goal was to do something that would provide some measure of visual progress. So the fuselage was targeted and we managed to:
Install the landing gear mounts
Installed the flap drive
Temporarily installed the fuel selector valve
Installed the Aux fuel pump
Moved the brake reservoir to the right for dual setup
Bent/formed the vent lines
Began to form the fuel lines
I'm beginning to realize that the hard part is
keeping parts on the plane. Seems like everything has to come back off 3 times before they stay on for good!
Gear mounts and fuel valve
Flap drive. I couldn't resist hooking up a battery and actuating the drive, and on the first transit it unscrewed from the rod end and I had to pull the actuator back out and screw it back in. it isn't lockwired yet. (Don't tell me you haven't done it!)
Vent lines.
Aux pump and main line to selector valve
Back to the right wing, we continued with the assembly. We had placed the outer leading edge on, and were on to the fuel tank assy. We have the fuel tank assembled to the point of back drilling the attach brackets, it was a good afternoon of work.
And then came Monday and I'm back at work toiling, and a text comes in from Annie, would I like to fly with her after work in her beautiful RV-9A! I had met Annie across the T-hangers at KBTL (where I keep my C120), and she had bought the 9A last summer. She's a CFI and accomplished pilot, and this was my first chance to fly a 9A.
What a thrill, this is going to be quite something!
N747RT
Transition lesson #1
And of course,,, The Grin
