Old 04-02-2019, 10:43 AM
romanov's Avatar
romanov romanov is offline
Question Testing fuel time with plain water ❓❓❓
Fellow builders,
I have sealed the tanks and still
dont have real fuel liquid close by.
Can I test the tanks with just watter?
How accurate is that testing?
Is it possible that watter won't leak
and 100LL later will.
Thanks a lot
Roman
Blogging my RV14 here:
https://bit.ly/2PzjPzS
Old 04-02-2019, 10:45 AM
BrianDC's Avatar
BrianDC BrianDC is offline
Planning initial leak test with water. Think that is the typical method.
Brian Lester
RV10 Slow Build - #41778
Finish Kit - in progress
RV10builder.com
KVKX / KHEF
Old 04-02-2019, 10:47 AM
romanov's Avatar
Sure, no bad in the initial try. But should I go
on and insist on real 100LL test?
Old 04-02-2019, 10:59 AM
Sam Buchanan's Avatar
been here awhile
Why not test it with air? Put a couple of PSI in the tank and spray the outside with soapy water, any leaks will cause bubbles to form.
Sam Buchanan
RV-6
Old 04-02-2019, 11:45 AM
romanov's Avatar
The back buffle is not riveted yet. I want to
be sure before I seal it completelly.
Old 04-02-2019, 11:46 AM
flyabq's Avatar
flyabq flyabq is offline
Default 100LL
Yes, Water has a much higher surface tension than 100LL. While it might not leak with water it doesn't mean that it is still 100% leak proof. You would be much safer to do the final test with either properly regulated air or 100LL.
The initial test with Water should be fine to test for larger leaks. If there are any of descent size then water will still leak.
RV6A project secured and working on getting it in the air.
Old 04-02-2019, 11:49 AM
lr172 lr172 is offline
+1
Without pressure, solvents, such as gasoline, can easily weep through spaces that water cannot, due to the lower surface tension.
Larry
Old 04-02-2019, 12:08 PM
romanov's Avatar
Question
Ok second question: is 95 octan as good as 100LL
for real tank testing ❓
Old 04-02-2019, 12:22 PM
flyabq's Avatar
Default mogas
I have never flown with MoGas. I am not sure what the surface tension is. If you are flying with MoGas checking with that should not be an issue. If you are I would use non Ethanol for testing purposes.
Old 04-02-2019, 12:25 PM
The gas is the same. 100LL just adds lead and some other additives to it and leaves out some additives found in auto gas. Surface tension of all gasoline is pretty much the same, as is it's viscosity.
