Is there a WnB program that I can play with that has the kit weight built with nothing installed? I am trying to figure out where to put the battery and LRUs etc
I used this manual by I-LUKE. You’ll have to convert from MM to inches. Just add/subtract your equipment and it will give you some idea of your potential W&B.
https://vansairforce.net/POH/Luke.pdf
Easy, build a profile in foreflight
I am struggling with this too. I have made so many changes as compared to the "samples " out there that I am at a lost for any indication if I will be tail heavy.
agreed a completed plane in foreflight is really easy i am talking about a skeleton airframe with nothing but the sheet metal and glass done with that base wnb you can calculate every once and where it goes prior to just throwing parts at it and hoping its close at the end.
