Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
06-21-2022, 11:12 PM
Originally Posted by Chkaharyer99
Teal,
What fuel are you running?
100LL but only for tuning purposes. Switching to 91 octane pump gas. will use 100LL when I have too
06-22-2022, 09:19 AM
VAF Moderator / Line Boy
One of the things I find exciting about Teal’s project is that we might finally get some long-term experience with these engines. The competition STOL guys have done great with them, but don’t fly as many hours as someone with a cruising RV - so we might actually get data on how long one of these lasts in real-world aviation applications!
Please keep us informed Teal….
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
06-22-2022, 01:01 PM
Originally Posted by kaweeka
My -9A has an IO-320 at 9:1 compression, dual lightspeed and AFP injection. I'm pretty consistent at 8,000-9,000 ft 147kts TAS, 6.7 gph, and 25* LOP. 64% power.
Ok, On this mornings flight I tried to duplicate some of the other RV9 cruise flight numbers.
At 8k ft and 150KTAS it was indicating 8.9GPH. at best RPM and manifold pressure which was 6300 RPM and 35.7INHg.
At 10k ft and 150KTAS it was indicating 8.5 GPH and 6300 , 35.3INHg.
Important to note that at these cruise numbers the AFR is still only 12.9-13. so there is much leaning to go in the tune at these manifold pressures. Also we are still tweaking on the fuel flow computer calcs each flight.
Perhaps of some importance is the above numbers represents about 20MPG (no winds). At the end of the last few flights I have drained the fuel and looked at total miles covered and it averages about 21MPG. That seems pretty good considering on the 1 hour flight I climbed to at least 12kft. Yes, I get some back on the glide descent but not equal.
In the end though my goal wasnt to try to get better fuel economy than the standard aircraft engine I think they do a great job of already.
06-22-2022, 02:08 PM
Teal, do you have a form of inflight manual mixture control? How about individual EGT?
Dan Horton
RV-8 SS
Barrett IO-390
06-22-2022, 02:24 PM
Teal,
What is best prop RPM at those speeds/altitude?
Thank you,
Charlie
RV-8
06-22-2022, 03:44 PM
No, with the exception of switching between preset fuel maps that was built prior. I am told that I can connect a potentiometer to one of the ECU's analog inputs for a manual mixture control but I am not really interested in doing that at this point. currently I am switching between a few different tunes during flight then going back through the log with my tuner guy and making fine adjustments until we have an all around good tune. I can always switch over to a for example lean of peak tune in the future if thats what I want but I am ot sure how exactly this engine will behave lean of peak yet.
06-22-2022, 03:47 PM
Teal,
Thank you,
I was kind of liking the 2200-2300 Rpm for this last flight but I have not spent to much time in the 8-9kft. Most of my time so far has been 12-15kft.
06-22-2022, 07:53 PM
Great looking install! With that much MP available, I would love to hear how it performs at 17,500. My O-360 -4 does pretty good up there, but starts to fall off above 15k. I would imagine the -9 wing gets more efficient up high.
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
06-22-2022, 08:23 PM
Those fuel flow numbers are not bad at all, considering. I would be very cautious about LOP operations on a turbo engine. If it was me flying that engine with the turbo performance up high on 91E10 or 93E10, I would be happy with the lower priced fuel and just run the factory tune - no sense burning a piston. I routinely see nm/gal readings of 21-23 in cruise flight, you're right in the neighborhood.
Garden City, TX VAF 2023 dues paid
N16GN flying 1,200 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Repeat Offender - 10 empennage in process.
06-22-2022, 10:27 PM
It climbs really, really good up high. But Cruise speeds are not as good as they should be. I feel that I am running out of propeller surface area, Not pitch because I can continue to increase pitch and still load the motor but increased HP is not equating to increased speed. Airmaster tells me this is the largest blades they can offer at this time. The highest that I have taken it was 15.5k and it will still climb around 1.5-2k ft per min. at 15k I think I was still able to make 44INhG manifold pressure. I am considering trying a fixed pitch propeller that performance up high. Sterna is telling me that they have a blade they want me to try. Anybody have experience with them?
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
