VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
Old 11-02-2022, 05:48 PM
SledDog SledDog is offline
Default Airflow Performance Purge Valve Return Line Location
My Thunderbolt IO-320 arrived and has an Airflow Performance purge valve installed. I understand the need for the purge valve and how to plumb it for an RV-9A. A big thank you to Tom at TS Flightlines for answering my noob questions. Also, thanks Kyle at Airflow Performance. I am trying to find the best location for the purge valve return line bulkhead. From what I have read on the forum, higher is better to prevent fuel from flowing freely into the hot side of the firewall through a damaged return line. If you installed an AFP purge valve, where did you locate the firewall bulkhead?
Thanks for any information, advice, pictures, or general comments.
Roger Grahl
Lac du Flambeau, WI
RV-9A Slider
Empennage - Completed
Wings - Completed
Fuselage - Completed
Finish Kit - Under Construction
Engine - Lycoming Thunderbolt Delivered
Panel - G3X / SteinAir Delivered
Interior - Classic Aero Delivered
VAF donation through December 2022
Old 11-03-2022, 12:21 AM
Bevan Bevan is offline
My return line firewall pass through fitting is located right next the other one that brings fuel to the engine which I believe is the Vans standard suggested location (lower center firewall near the fuel pump).
For better or worse, the other end in the tank is located at the highest forward point in the inner most bay. Not sure if this is best or the only way but itís what was recommended to me at the time and has worked well so far. 370+ hrs.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 11-03-2022, 01:20 AM
rv8ch's Avatar
rv8ch rv8ch is online now
Same as Bevan - very close to where the fuel comes in on the firewall.
Not sure I understand your concern about the damaged fuel return line FWF - that line only sees fuel flow at startup and shutdown. Take care to use good quality fuel line, route it carefully, support it where needed, ensure that it's on tight, and check the b-nuts regularly.
Mickey Coggins
http://www.rv8.ch/help-people-in-ukraine/
Old 11-03-2022, 02:05 AM
planenutz planenutz is offline
On my RV-6 I have the Purge Return pentrating the firewall at a position quite high on the right side of the firewall, just under the horizontal angle. I took the return line through the firewall then placed it parallel to the fuel vent line all the way to the tank. This allows you to brace the two aluminium fuel lines together for mutal support. Fuselage/Wing Root penetrations are beside each other, as are the tank penetrations.
As an aside - I ended up placing a decal on the instrument panel next to the fuel pump (and a second decal next to the fuel valve) recommending the right tank is selected for purging prior to hot starts. Reason - During the test phase I purged the system prior to a hot start with both tanks full to the brim with the left tank selected. Fuel in the right tank ended up venting out and made a bit of a mess. Not a huge issue... just something I'd not given a lot of thought to prior to it happening.
Mike
Licensed Aircraft Mechanical Engineer
PPL-A
RV-6, ZK-XTC - Superior IO-360, Sensenich FP, GRT EFIS, Surefly SIM
Bolkow 209-160RV, ZK-MON - IO-320, MT Prop, Retract Nosewheel, Folding Wings
Trustee and Technical Councillor for the MBSAT RV-12 builds in Whitianga
Old 11-03-2022, 09:07 AM
Default I think the bulkhead is below the fuel tank level.
Thanks, everyone, for replying. This is helping a lot. Here's my dilemma: I do not have a dedicated fuel return installed in my tank. According to Airflow Performance's installation manual, I should install a tee in the fuel feed line.
Here's the AFP schematic:
If I locate the return bulkhead fitting next to the fuel supply fitting (location 'C'), I think this will place the return line bulkhead below the full fuel level. If the purge valve return line or bulkhead is damaged on the forward side of the firewall, fuel could gravity feed freely into the engine compartment with no way to shut it off. Location 'B' may be above full fuel level. Location 'A’ is above full fuel level but creates a return line routing challenge behind the firewall.
Here's OP-32 and I have marked the three purge valve return line bulkhead locations I am considering:
Again, thank you so much for responding. I'm sure I am either over thinking this or just misunderstanding something. I'm also sure other builders have resolved this issue...if it is an issue.
Roger Grahl
Lac du Flambeau, WI
RV-9A Slider
Wings - Completed
Old 11-03-2022, 12:02 PM
n816kc n816kc is offline
Default Purge tie in
I originally had mine tee’d into the fuel feed, found it introduced air bubbles into the system (at least that’s what we came up with) resulting in rpm surge when it happened. Changed it to the vent line and the issue went away. You can pump fuel out the vent with An overly long purge, but that isn’t necessary
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2022 =VAF= donor
Old 11-03-2022, 01:48 PM
As the purge retun is on the right side of the engine you would probably be better with something close to location A.
Using your picture, mine goes through the firewall below the "2" in the "VA102" printed on the schematic, but on the underside of the horizontal angle. This brings it closer to the vent line.
The reason I ran the line back to the tank was to get rid of the warm fuel and vapour so that fresh cool fuel can be introducted, avoiding recirculation of the hot fuel back to the engine. Adding a bulkhead fitting for this input into the tank was no hassle.
Mike
PPL-A
Old 11-03-2022, 02:02 PM
Walt's Avatar
Walt Walt is offline
As noted above definitely better to run it back to a tank.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 11-03-2022, 02:22 PM
rv8ch's Avatar
Perhaps add a valve between the purge valve and the connection to the return tank.
Name:	Airflow Performance Purge Valve Drawing.png
Mickey Coggins
Old 11-03-2022, 03:14 PM
N427EF N427EF is offline
Default return valve
A return valve is what I installed.
It solves your concern over a damaged fuel return line, I assume you are thinking of an accident scenario where your return line would uncontrollably spill fuel from the tank to a firewall forward location?
If you install a valve you can pretty much install that bulkhead fitting anywhere you please.
You can plumb your return fuel to either tank or both as in my installation.
I used Vans provided fuel valve for the return and an Andair for the supply side.
This approach also allows you to transfer fuel from one tank to another if you so desire.
If all you need is a return for your purged fuel, you can simply open the valve for purging and close it off after.
This set up is a great start if you later decide to use mogas and want to accommodate a constant flow return system.
Ernst Freitag
RV-8 finished (sold)
RV-10 IO-540 8.5:1
Running on 91 Octane E10 mogas since 2011
We all get what some of us deserve
