Just wanted to share the install I just did on my Red Cube.
After looking at numerous different installs, I decided to go with the install bracket by TS Flightlines/Aircraft Specialty. A nice turnkey option that is very well documented.
The core of the kit is a beautiful custom bracket and hose. The install has you move the outlet from the bottom of the fuel servo to the top which I think is much cleaner. and also remove the 90° fitting from the flow divider and install a straight one.
I was worried the bracket bolt would be a difficult chore but ended up being a non issue and the install was a breeze. It's nice to have this job behind me
