Keep VAF
Going
12-08-2012, 09:43 PM
Hot #3 CHT - Solved!
So in the course of changing out my injector lines, I decided to attack my #3 cylinder temperature issue. This cylinder has always been my "problem child" on climb and also in cruise. It typically runs hotter than my coolest cylinder (#4) by a wide margin (usually about 70 - 80 degrees in the summer) in cruise. Always. Anyway, I decided to deconstruct the rear baffle and see what I could do to direct some air through the fins. Then it struck me... With the Vans supplied baffles, there is no way air can get from the top of the cylinder to the bottom on the intake side of the head because the fins terminate at the equator of the cylinder. The wrap around baffle on the bottom has essentially no supply of air. So not only is there no airflow around the bottom, the top fins are simply radiating heat into stagnant air. So I figured we needed to get some air moving past the top and bottom fins to see if the temps would come down. I fabricated a plenum to get the air moving in an organized fashion and attached it to the existing baffle.
Long story short, I finished it up this afternoon and was blessed with good flying weather. I decided to climb to my normal cruise altitude of 7500 feet to see if the mod did anything. I tried an agressive climb to stress the cooling and was greeted with the typical #3 cylinder behavior of leading the numbers. Great! All that work for no gain. But as I pushed over into cruise, the temps started to fall. And wouldn't you know it, the problem child kept falling - eventually stabilizing at a temp only a few degrees warmer than my coolest. So this one fairly simple mod brought my hottest cylinder all the way down to the second from coldest. Now my hottest is #2 - which also features the same airflow blockage by virtue of the Vans baffles. Time to work on that one and get it into line with the others.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
1940 Taylorcraft BL-65
1984 L39C - SOLD
RV-8 - SDS CPI - SOLD
12-08-2012, 10:16 PM
Good Deal!
Greg
Greg Arehart
RV-9B (Big tires) Tipup @KCLM or CYSQ
N 7965A
12-08-2012, 10:18 PM
Senior Curmudgeon
This problem has been discussed here quite a lot, usual fix is a washer between the baffle and cyl.
Dan H. did a mod similar to yours, but nowhere near as large----actually he did a couple using different methods..
As long as it is working, all is good
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
12-08-2012, 10:26 PM
The washer trick can't move enough air, IMHO. A washer also does not allow any control over where the air is going. It simply makes it "less" stagnant back there.
Michael Robinson
______________
1984 L39C - SOLD
12-09-2012, 08:32 AM
Mike's approach has a subtle difference compared to the short ducts I outlined for bypassing the no-fin-depth head section. In Mike's scheme air must first pass between the fins on the upper intake quadrant in order to follow the bypass duct to the lower fins. Between fins is always superior to willy-nilly flow in the general vicinity of the fins. I suspect if you measured the air temperature at the baffle exit below the cylinder it might be a bit warmer than with the short duct under identical conditions, meaning it picked up more heat. That is the goal.
Previous discussion here:
http://www.vansairforce.com/communit...ad.php?t=37835
Mike's approach on the right. My own #3 runs abut 25F warmer than the others. The little hammered duct might be on the small side, plus it gives up some heat transfer from those upper fins. I've just been too lazy to fool with it.
Dan Horton
RV-8 SS
Barrett IO-390
12-09-2012, 09:12 AM
Thanks Dan for the illustration. And yes, pulling air through the top fins was one of the objectives. Though it was "fiddly" to make and fit to a flying airplane, it was very effective. On yesterday's flight, I would have expected to see that cylinder 50 degrees warmer than it was.
I am more than a little surprised how often you see baffling like this. I know it is up to the airframe designer to come up with the cooling system, but damming up the airflow on #3 (and #2, for that matter) seems like a significant oversight. Seems like the Z bend in the baffle should be lower on the cylinder so the bottom bend is not adjacent to the "zero fin depth" region. Following the plans, the lower shroud serves no purpose... In fact, you would likely be better off removing it so all the fins could at least radiate.
Also, should have checked to see if this had been discussed on the boards before... I see that you have thoroughly illustrated the issue in the other thread (at least I got to bask in the glow of my own genius for a day...).
Michael Robinson
______________
1984 L39C - SOLD
12-09-2012, 01:47 PM
Just got back from a longer flight and it looks like #3 and 4 are matched within a degree or two. 7500 feet, 51 OAT and 50 LOP I saw 3 and 4 stabilize at 299 while 1 and 2 showed 310 and 318 respectively. Pretty sure that once #2 gets some airflow to the bottom fins it will come into line as well.
Michael Robinson
______________
1984 L39C - SOLD
12-09-2012, 03:20 PM
Good result!
David Brown
12-10-2012, 04:14 PM
hot #3 CHT
Michael,
I was recently down at Gami injectors to have my fuel flows evened up. They include a baffle kit for the turbo bonanzas that includes your mod for the rear cylinders. They found directing the air around the back cylinders of the engine, dropped the CHT down. I plan on doing the same thing while I am installing cowl flaps on my RV10 -- winter project...
Greg...
www.nwacaptain.com
12-16-2012, 05:27 PM
OK, decided to take a crack at getting some air around my #2 cylinder ( now my hottest, as reported). Since I have the inlet mounted servo snorkel, I don't have much room to put a large plenum like on #3. So my plan was to go extra wide to make up for the very narrow "air inlet" which as you can see is simply 4 of the existing rivet holes enlarged to 1/2 inch. Capturing the air is a simple wedge shaped .6x4x2.5 inch plenum riveted to the front side of the existing baffle. A simple window was cut to allow an exit for the collected air. Also, I completely removed the "baffle dam" in front of the head fins since there is no way for the air to go "down". At least the in rushing air will have a better chance of carrying off heat this way.
Flight test today revealed that the mod works well, as this is now my coolest cylinder by 10 degrees. I would have expected to see 320 - 315, but it was down to 290. So overall I'm pretty happy with seeing all 4 cylinders under 300 in cruise. Heck, I might need to start necking down the air inlets if this keeps up!
Michael Robinson
______________
1984 L39C - SOLD
Thread Tools |
Display Modes |
