  #11
Old 05-18-2021, 08:30 AM
rvbuilder2002's Avatar
Originally Posted by BillL View Post
This would be true if the sensor is measuring both engine usage and bypass flow. A less than desirable way to plumb the system, it would seem, although it could work nicely with internal calculations instead of a direct reading panel result, or the bypass is very small, like to prevent vapor lock or for vapor collection and purge.
This is exactly how the system is designed, and operates.
edit - I see this is a linear shuttle pump and with the pressures must be a carb. I don't understand where this orifice bypass is. Sorry for confusion.
You are posting to a discussion in the RV-12 forum. The RV-12 has two carbs actually, and because of that, a fuel system that is a bit different that what is common on the rest of the RV models.
Scott McDaniels
Hubbard, Oregon
Old 05-18-2021, 11:40 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
So, several flights now with the new 40135 Facet electric fuel pump. Looks like 0.3-0.5 add'l fuel flow showing in cruise flight. I'll adjust "K" factor at some point - just not now.
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 670
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 05-18-2021, 12:15 PM
seagull seagull is offline
I am seeing similar in fuel flow but will trend it for a few more hours to be sure. I do not see the fuel remaining changing though.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 05-18-2021, 04:55 PM
darata darata is offline
Originally Posted by lr172 View Post
The red cube DOES have an impeller, though you are correct that it uses an optical sensor to count the impeller revolutions.
Correct!
Dave Arata
Sales/Support
Electronics International
Old 05-18-2021, 05:16 PM
Taltruda Taltruda is offline
The red cube DOES have an impeller, though you are correct that it uses an optical sensor to count the impeller revolutions. The K factor is used to convert fractional impeller revolutions to GPH.
Larry
I love it when I learn something! You are right! I thought these were purely optical.. Hereís a Bearhawk guy taking apart his FT-90 gold cube.. I assume they are similar in construction..
Thanks!
https://youtu.be/HXJMLcpcl10
Tom
Las Vegas
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 05-18-2021, 10:40 PM
RFSchaller RFSchaller is offline
In the end the value of the fuel flow rate is more significant for its consistency than the absolute value. When I see a value Iím not used to it raises an eyebrow.
