  #21
Old 03-16-2021, 09:49 AM
JFCRV12 JFCRV12 is offline
Originally Posted by RFSchaller View Post
Bite your tongue, David!��
Agreed! I didn't build my plane, but feel like I'm slowly rebuilding it one SB at a time
Actually, it hasn't been that bad. But I do have to do the gear leg and engine mount standoff in next couple weeks (I have the parts). Time and a helper are all I need.
Still an excellent aircraft. And experience tells me ALL aircrafts break and have/should have a litany of SBs on them.
2021 Dues Paid!
Old 03-18-2021, 01:26 PM
Piper J3's Avatar
Piper J3 Piper J3 is online now
Weld repair is complete. Chromoly 4130 split over-sleave is TIG welded into tubing cluster.
Third photo shows weld fixture to hold 189mm vertical centerline distance for engine mounting pads.
On closer inspection… on the left side of the mount (broken side) I see heavy internal thread markings in both the top and bottom engine mounting pads. See photos below. I think this engine mount was made incorrectly from the get-go. My guess is the 189mm vertical centerline distance was compromised during initial fabrication, and when assembled to the engine, it caused tension and stress in the lower tube.
Engine mounting pads on the right side of mount look pristine. Now that mounting pad centerline dimension is corrected with this repair, everything should be hunky-dory.
Click image for larger version
Name:	Screen Shot 2021-03-18 at 3.19.24 PM.jpg
ID:	9447  Click image for larger version
Name:	Screen Shot 2021-03-18 at 3.19.14 PM.jpg
ID:	9448  Click image for larger version
Name:	Screen Shot 2021-03-18 at 3.19.44 PM.jpg
ID:	9449  Click image for larger version
Name:	Screen Shot 2021-03-18 at 3.23.19 PM.png
ID:	9450  Click image for larger version
Name:	Screen Shot 2021-03-18 at 3.23.06 PM.png
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 670
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 03-20-2021, 10:25 PM
cactusman's Avatar
cactusman cactusman is offline
It's too bad Van's didn't have one they could exchange and bring yours in for extensive testing and analysis.
Just curious with that time - had you had the carbs rebuilt and do you balance them often or at least annually?
Also - prop balance? Recent or at the initial stages like most of the rest of us did?
Really think the key to long life on this plane is getting those vibrations out and keeping them out.
John
RV12 Built and Flying
RV10 Started
Old 03-21-2021, 06:09 AM
Piper J3's Avatar
I rebuilt carbs last year and synch checked annually.
This year I will balance prop for first time. I will be interested to see balance improvement. Engine runs extremely smooth at cruise and off-idle.
Reinstalling repaired engine mount - where do all these hoses go???
Name:	Screen Shot 2021-03-21 at 8.12.14 AM.png
Old 06-02-2021, 01:34 AM
Piper J3's Avatar
I have added a third photo to my post #1 above. I am in contact a RV-12 builder/owner in Australia. He has now discovered a second crack in the main circular back mounting ring after disassembling cabin heater control cable. He is in process of installing new engine mount after discovering crack on lower right side near oil tank. I would think main circular back mounting ring is very robust and that cracks would appear in thin tubing where engine attaches, like in my instance.
Just a heads-up when doing next condition inspection…
Old 06-02-2021, 07:04 AM
JBPILOT JBPILOT is offline
Default Another victim - -
I found my standoff mount was cracked more than half the way around on the cross tube. I have no idea what the fix is from Van's, but I ordered it. 1,450 hours. I have balanced prop I think 3 times, and sync carbs every year. I decided not to weld it, but did consider it. Not sure it won't break beyond the weld fix area. Engine torque I assume causes this problem. Hopefully the factory fix will last a long time.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-2021 )
