Originally Posted by snopercod
I have an AFS "Sport" AoA. It's a stand-alone unit with a small .040" port on the top of the outboard wing and another on the underside. I mounted the LED bar graph display immediately to the left of my ASI so it's in my peripheral vision while landing. In a Lancair, it's a must-have safety device:
I have the same unit, with the multiple light readout mounted center of the RV4 tip up canopy rail, almost as good as a HUD. Lights come on from bottom up first. Did some extensive flight testing:
1. Best Glide, MaxEndurance and Best climb angle - all green and first of three yellow lights on (like Snopercod picture)
2. Best App No Flap - all green, first and Second of three yellow lights on
3. Best turn rate (hack it, rack it, track it) - all green, all yellow and occasionally first red.
Unit has audio, but I don't use it - too annoying
Always know approximately what mph lights indicate. (little plastic tubes fell off the sensor once) For instance for my RV4 at low fuel and FLAPS DOWN:
1.One green always On
2. two green = 71mph
3. two green and three yellow = 59mph
4. two green, three yellow, two red = stalled (49mph)
FLAPS UP:
2. two green = 99mph
3. two green and three yellow = 74mph
4. two green, three yellow, two red = 62 mph
5. two green, three yellow, three red = 60 mph
Didn't stall until ~ 55 mph
ALL ABOVE ONLY CORRECT FOR MY AIRCRAFT!
