Lucky I didn't do the bolts then...
Read up on the technical. Minimum weakening in this application. Protection from weather corrosion probably worth the trade off.
Kill joys.....
If you are heavier ( I am 215# , 6' tall ), the original step can break off with enough use. It is a real surprise to find yourself laying on the ground, hopefully not too hurt. Still could be welded on to repair as I did, but the chrome would sure get messed up.
where it changes shape to enter the fuse. Not much metal there. If you had someone video - level with the step as you climbed in, you might be surprised at the deflection. Mine feels very solid now. The other side does not.
