Old 07-19-2022, 11:29 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default RV7T build by Turbaero
RV7T build (RV7AT actually) should be interesting to watch.
https://www.youtube.com/watch?v=vZwGshhB6sk
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 07-19-2022, 11:32 PM
z987k z987k is offline
Oooh vaporware on the front of a chunk of aluminum! I wonder if they'll put that 3d printed mock up on there and tell the people that stop by the booth to make turbine noises with their mouth.
Old 07-20-2022, 04:46 AM
David Z David Z is offline
I wish them the best and hope they succeed. I also appreciate the challenges they face.
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage assembly, it's a riveting job!
83126
Dash 8 day job is financing the RV8
Donation till September 2022
Old 07-20-2022, 07:02 AM
Having seen this project from very early on, I too was intrigued. Yep, lots of development problems, but from our converstations with Dave, I think they have most worked out. We may be doing the FWF hose package for them.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 07-20-2022, 12:49 PM
DanH's Avatar
DanH DanH is offline
It seems more than a bit irresponsible for a vendor to put a turbine on the RV model which has most often come apart due to overspeed.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-20-2022, 12:51 PM
PilotjohnS PilotjohnS is offline
Default Rocket
I agree, should be on a Rocket.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done less baffles and airbox
Fiberglass 95%
www.pilotjohnsrv9.blogspot.com
Old 07-20-2022, 01:11 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Dave and team strike me as a pretty learned bunch, unlikely to risk either themselves or their early engines by doing stupid pilot tricks.
The turbine won't put out much more power at altitude than an AV 360 unless it's flat rated.
Several turbocharged 7s have exceeded 210 KTAS in level flight, at least one at Reno, AVERAGED over 220 kts so it's going quite a bit faster than that down the straights.
I believe Dave owns a White Lightning and has plans to put the Talon engine in that at some point for higher speed testing.
The -7 seems like a good and popular airframe to test the capabilities of the Talon engine, set up typical engine mounts and supporting systems with lots of room and see how the C of G works out.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 460.7 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
Old 07-20-2022, 03:55 PM
DanH's Avatar
We can say the same for the pros flying the OSH airshow next week. It's the Bubbas who get killed.
Then why would anyone want it?
Seriously, from the vendor site..."an optimum cruise power at 10,000’ in the range 150-180hp with a targeted specific fuel consumption of around 0.56 lbs/hp/h..." and "Optimum cruise power 180 hp"
Ahhh, perhaps it's bad form to encourage the Bubbas?
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-20-2022, 04:06 PM
g zero g zero is offline
Default Turbine
Looks like some foam and plastic glued together….. at least The Infamous Egg …. Had a running engine to promote
Rv8
N 666 TA
First Flight 2-3-2015 🚀
Old 07-20-2022, 04:58 PM
unfluencer
Default Soon to be a VAF advertiser.
I couldn’t agree more with those looking forward to seeing this being built! TurbAero will soon be an advertiser here, helping me keep the lights on and these forums online. They will be documenting the build in the forums in their own ‘My RV Build Project’ thread. I should have their ad live here in a week or so.
I talked w/Dave for an hour or so last week and went through some of the challenges they are addressing/facing. It seems (to me) to be a fascinating project.
Experimental aviation!
V/r,dr
Doug Reeves (your host)
"Don't ask me....I'm just improvising."
  • Available as Contract Pilot (ATP. PIC typed in G-V(450/550) and Phenom 300). Flying resume.
  • Part time: G450/550 and Phenom 300 seat support at CAE (KDFW).
