Old 03-28-2021, 12:36 PM
Freemasm Freemasm is offline
Default Glare shield underside color
Note: this is not an interior color choice thread/debate.
I’ve seen a lot of various pix. What color did you utilize for the underside of your glare shield?
My thought was a non-reflective black like most use on the top. My thinking was that would visually keep focus on the panel (though it will help radiate heat downward).
What did you do? What would you have done differently?
Much thx.
Old 03-28-2021, 01:12 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default alclad
Mine's alclad, nice and shiny, and I can't see it when flying. I could have painted it pink with green polka dots and wouldn't know it. Might be different on other models.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 03-28-2021, 07:23 PM
RV10Pilot RV10Pilot is offline
I painted my the same flat black that is on the top of the glair shield. Now when I crawl under the panel to work on something it looks nice and finished LOL.
Old 03-28-2021, 08:14 PM
elev666 elev666 is offline
Mine are both painted white so I can see while doing head stands under there , makes it so a little light goes a long way !!
RV 6. GARV
1946 C85 J3
RV 7 A project
Grounds keeper @ CKS9, 2020 dues gladly pd
Old 03-28-2021, 09:47 PM
mfleming's Avatar
mfleming mfleming is online now
That's a great idea
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring completed
Avionics harness build in progress
Donated for 2021 and so should you
